First PC build need help
Superherofan
Commendable
Mar 18, 2016
I'm planning to build a PC ,I'm a noob in building PC , I have never built a PC before but I did a few research and came up with the following components for my gaming PC
CPU: Intel core i5 6500
Motherboard : MSI Z170A PC Mate - LGA1151 - 6th Generation
Graphics card : Asus Nvidia GeForce GTX 960 Strix DirectCU II Graphics Card
Ram : 8GB DDR4 Kingston HyperX Fury Black Series 2133 MHz DDR4 CL14 288 Pin-DIMM Memory - HX421C14FB/8
Power supply: Corsair CP-9020098-UK VS Series VS650 650 Watt Power Supply Unit
HDD: WD 1TB Blue Desktop Internal Hard Drive (WD10EZEX)
Please let me know if something is wrong like compatibility or if I need to change something . I want it to run games like GTA v black ops 3 and other future games in high settings . I live in India my budget is near 60000₹ (700$-800$)
- you should not put a locked cpu on a Z170 mobo. If u plan to overclock than u should get a K cpu (in this case the i5-6600k) and keep the Z170 motherboard, otherwise get an H170 mobo and a NON-K CPU
- I don't know what is the opinion about Corsair VS series in USA, but in Italy is pretty bad. If you are on a budget better to get an Antec Earthwatts bronze, XFX TS, Antec TruePower, Antec EDge, EVGa gs/g2/gq
- gtx 960 is a good card for fhd, but Amd R9 380 4gb will suit much better.
I can't afford i5 6600k nor the r9 380 , but is over clocking necessary ? And OK I'm gana change the power supply .changing mobo to Asus H170 Pro DDR4 - LGA1151 - 6th Generation MotherBoard , if overclocking is not necessary
PS thanks for the reply
