Hi, I wanted to ask for your input on my first PC build. What I will be using this PC is for some gaming, photoshop, and general use. I have bought some components already and have to buy majority of them. If you could tell me which of the components will be good that would be great. OK here we go:
CPU: i7-930 bought from microcenter
Mem: OCZ DDR3 PC3-12800 / 1600 MHz /Gold Edition / Triple Channel Kits (6GB, bought already)
Video Card: XFX HD 5770 XXX edition--> newegg has it for 170 with shipping (don't want anything to hardcore just something bang for the buck)
PSU: I was thinking either Corsair HX650 or XFX P1-650X-CAG9 650W XXX Edition ( I want something modular just cause of the cable management)
Case: Either Thermaltake V3 black edition or Gladiator 600
CPU Cooler: Either Coolermaster hyper 212 plus or Thermaltake Contac 29 or Dark Knight (I want to try to overclock, never done it and would want to do it for a overclock of 3.4-3.6 ghz if possible with these coolers)
HD: Western Digital WD5000AAKS Caviar Blue Hard Drive - 500GB, 7200rpm, 16MB, SATA-300, OEM
DVD: LG GH22NS40 DVD Writer - DVD+R 22x, DVD+RW 8X, DVD-RW 6x, DVD-RAM 12x, SATA,(OEM)
Memory Card Reader: any suggestions?
Motherboard: I was having difficulty deciding between ASUS P6T/P6T SE or EVGA X58 3X SLI. I found the EVGA for 214 after BCB and ASUS ones for 200 after BCB (not SE one)/170 after BCB (SE one). I was just confused because on some forums people have problems with the memory I have with these boards, I really liked the EVGA board and plus I heard they have good support and comes with lifetime warranty.
I was also wondering if you guys could recommend case fans for my case, want to have adequate cooling.
Any help would be appreciated, if you can help me narrow down from the parts I have that would great.
Thanks in advance
Thanks in advance
