First pc build
Good, but minecraft will hurt with that processor. do not get the 4130, at least get the 4300, if not the 6300 is the best bang for your buck.
recommended build:
PCPartPicker part list: http://pcpartpicker.com/p/2Gzql
Price breakdown by merchant: http://pcpartpicker.com/p/2Gzql/by_merchant/
Benchmarks: http://pcpartpicker.com/p/2Gzql/benchmarks/
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($114.98 @ SuperBiiz)
Motherboard: ASRock 990FX Extreme3 ATX AM3+/AM3 Motherboard ($109.99 @ Newegg)
Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1600 Memory ($76.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.67 @ Amazon)
Video Card: Asus Radeon HD 7770 2GB Video Card ($114.99 @ NCIX US)
Case: NZXT Guardian 921 RB ATX Mid Tower Case ($69.99 @ Mwave)
Power Supply: Corsair Gaming 600W 80+ Bronze Certified ATX Power Supply ($69.99 @ TigerDirect)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($16.98 @ OutletPC)
Total: $633.58
ik it is $630 but it is so much better than the Build you have there, worth the extra 30. (side note, the stock heatsink/fan with AMD fx cpus gets quite noisy when gaming, just a heads up).
I like it but do you think there is anything i can go cheaper on because im on a really strict budget and really dont want to go over 600
PCPartPicker part list: http://pcpartpicker.com/p/2GAm6
Price breakdown by merchant: http://pcpartpicker.com/p/2GAm6/by_merchant/
Benchmarks: http://pcpartpicker.com/p/2GAm6/benchmarks/
Memory: A-Data XPG V2 8GB (2 x 4GB) DDR3-1600 Memory ($69.99 @ Newegg)
Case: NZXT Guardian 921 RB ATX Mid Tower Case ($68.89 @ Amazon)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($49.99 @ Microcenter)
Total: $605.48
Best I could do to bring it down close to ~$600
