Nov 7, 2024
Hello people.
This is my first PC build ever and I was wondering if you can share your knowledge with me. Are there any issues with the components I have chosen ?
CPU: AMD Ryzen 5500
GPU: AMD Raden RX 6600 or any other version of this GPU such as Swift
Motherboard: Asus B550M-A/CSM DVI/HDMI/M.2
RAM: Kingston DDR4 8GB 3200MHz KF432C16BB x2
Cooling: Cougar I Forza 50 I 3MFZA50.0001 or Arctic Cooling Freezer 7X CO.
Power: Raidmax 650W RX-650XT(B) Black/120mmTC fan/si bulk
Storage: Samsung 1TB M.2 nvme MZ-V9P1T0BW 990 pro series SSD
Case: LC Power 2014MB-ON 2xUSB2.0/1xUSB3.0 Black
Lutfij
You're advised to stylize your thread with info asked of in this thread;
including your location, your budget, your preferred site for purchase and what this system will be used for, essentially everything asked of in that thread. The community can then move forward with constructive suggestions.
Moved thread from Components section to Systems section
Ryzen processors prefer a tight latency dual channel DDR4-3600MHz ram kit, that Raidmax PSU is a horrible unit and that case will cook your internals, not to mention that the max CPU cooler clearance you have in that case is 135mm so the Cougar cooler won't fit in it. If you're building on a budget, use the stock air cooler that comes with the processor.
Oct 10, 2024
23
Hello people.
This is my first PC build ever and I was wondering if you can share your knowledge with me. Are there any issues with the components I chose for the PC?
CPU: AMD Ryzen 5500
PC for work, gaming or what? clarify plz
Nov 7, 2024
Thank you for you suggestions. Here are some clarifications.
Approximate Purchase Date: This or the next month
Budget Range: 640 euros
System Usage from Most to Least Important: Gaming, surfing the web, watching movies
Are you buying a monitor: No
Do you need to buy OS: No
Preferred Website(s) for Parts: Eponuda, its a website that allows you to compare prices of products from other websites https://www.eponuda.com/
The websites of the parts are picked are https://itprodavnica.rs/ https://bazzar.rs/ https://www.ekupi.rs/rs/ https://ananas.rs/ https://www.frog.rs/
Location: Serbia, I am only buying from the local online stores as you've seen
Parts Preferences: AMD for GPU and CPU, otherwise no preferences
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: 1920x1080
Overall i want to get the most out of my money. I intend this build to be purely performance based and either within or close to the budget listed. I have the least confidence in my power and case picks.
Parts list:
CPU
: AMD Ryzen 5500
https://www.eponuda.com/racunari-pr...cores-3-6ghz-4-2ghz-box-procesor-cena-6507636
https://www.ekupi.rs/rs/Računari/Ra...-5-5500-3-6-4-2GHz,-6C-12T,-AM4/p/EK000533949
https://www.frog.rs/proizvod/mb-am4-asus-prime-b550m-acsm
RAM: Kingston 2 x 8GB DDR4 PC3600 KF436C17BBK2/16
https://itprodavnica.rs/shop/produc...mhz-kingston-fury-beast-kf436c17bbk216/141185
Power: DeepCool PF600 or LC Power 600W LC600H-12
https://bazzar.rs/p/EQ5N352-deepcoo...2x-4pin-2x-pci-e-6-2-x2-1x-eps-8pin-4-4-120mm
Storage: Samsung 1TB M.2 nvme MZ-V9P1T0BW 990 pro series SSD or Crucial ssd P3 500GB m 2 2280 pcie Gen3 0 3D nand for a more budget frendly alternative. I might also get a hard disk in addition and wonder if its possible to have both at once.
https://www.ekupi.rs/rs/Računari/Ra...-990-PRO-M-2-NVMe-(MZ-V9P1T0BW)/p/EK000576987
Case: Aero Cool Hexform-G-BK-v1 ACCS-PV38013.11 or Asus A21 plus tg argb micro-atx or UGD Elite 3718.
https://bazzar.rs/p/A63Q9N3-kuciste-aerocool-hexform-g-bk-v1-accs-pv38013-11
https://itprodavnica.rs/shop/product/kuciste-ugd-elite-3718/148394
