[citation][nom]ZakTheEvil[/nom]I know there is not a loot room for this even on a double-height card, but I'm still wondering if it would be possible to design a card that draws cool air from the *outside of the case* and exhausts it to the outside as well and whether that would even make a difference. It seems all current cards intake the internal air which is already warmer than outside, ambient air.[/citation]
The problem with that is that unless you have a side intake fan on the chassis for the cards, they can't really do what you said because then you would need intake and exhaust both in the small external area from the PCIe slots of which the display connectors already take up a large portion. You would have one or two slots's worth of area at best to fit both intake and exhaust into. Maybe with a three slot card,the top slot could be exhaust, the middle slot could be display connectors, and the bottom could be intake, but otherwise, I just don't see it being done and even then, I'm not sure if it would be very practical.
