First System Build
GiorgosKorn
15
Hello there
first of all i would like to gongratulate the toms hardware forums for helping me out about this
I want to build a budget computer(around 800 euros) and i want you to tell me your opnion between these two
PC 1(worth 769 euros):
Case: Corsair Carbide400R
Power Supply:550W
Ram: Corsair Vengeance 8 Gb DC 1600MHz
HDD:Sandisk 64Gb and Seagate 1Tb 7200rpm 6gb/s
GPU: PCIX7790 GDDR5 1gb
CPU:AMD FX 8350
Motherboard:MSI 760 GA-P43 FX
PC 2(worth 855 euros/852.60):
Power Supply:550W
GPU😛CIX7790 GDDR5 1gb/Palit GTX 650Ti OC 1GB
CPU: I5 4670K
Motherboard:MSI B85-G43
Edited:
PC 3(worth 825 euros):
Power Supply:550W
CPU: I5 3570K
Motherboard:Gigabyte GA-B75-D3V
Tell me your opnion because in 4 days im buying something
Thanks in advance
PS: Corsair Carbide400R or Zalman z11 plus?
I actually like the Zalman Z11 Plus, I built my system with it.
The 8350 should last you a good while. I think you'll be fine. The i5 is actually worse at rendering and heavily multithreaded tasks like editing, etc.
The 8350 makes more sense for you. If all you did was game, then Intel would be a good fit too, but with your rendering and music needs, the 8350 should be a better performer for less money.
What are you doing with it?
EDIT: Gaming? Overclocking?
Let me say this, if you're going to be doing mostly productivity, the AMD will be effective and save you money. If you're going to be gaming, and want to go Intel, the 3570k is a better buy than the 4670k. You will get virtually identical performance in games and save yourself on the order of $60 or more depending on the components you choose.
For gaming, the 3570k has a slight edge over the 8350...it's usually about 3-5 FPS .
Even Tom's Hardware does not recommend the 4670k for a gaming CPU. They recommend the 3570k.
I am doing anything all of them are part of my daily schedule gaming/music production/rendering so 8350 would be fine or go for the i5? and two more things... if i choose 8350 how many years would it last? and what case should i take the carbide400r or zalman z11 plus?
Alright I think i came to a conclusion with the 8350 build and i will see about the case. One last thing 550watt power supply is fine?
8350 along with the 7790 will run games like bf3 fc3 crysis3 etc...?
Well this card costs 200 euros here in greece while the 7790 costs 150 euros i am going to check out the benchmarks to see whst better for my needs in this 😀
Thank you for your time 😀
