Never built a system, so I'm sure there's a chance when I get to it, I'll be back with more questions. But I'm pretty good at researching on my own. Believe it or not, I'm not the most computer savvy person on a regular basis, but I can narrow down reviews like a madman. 2 days of work and here's where I'm at.
I'm not much of a gamer at all, but I like the option if it happens to come up, so nothing too graphic intensive is necessary. I contemplated just going with the integrated graphics, but if anything, multiple monitors might be in my future, and I heard doing the DVI/VGA isn't the best, plus possible games. Anyway, look at the system and this might make sense.
I do heavy browsing, lots of tabs, some photoshop at times, not a ton. But my main goal was to build something semi future proof. I splurged a bit on the USB 3.0 case and Mobo. Plus I really like the reviews and features this mobo seems to have, so biases aside (Since I didn't have one to start with), this seems like a good one. Open to suggestions on anything though.
Sorry, still rambling, just trying to get my reasoning out there. Overclocking could be possible, probably not extreme OC though. Just for funsies, maybe even the auto option that seems to be in the Asrock BIOS. I wasn't sure if I would need a heatsink for that, but the case only has 2 fans, so I figured better safe than sorry, but I'm open to suggestions on that.
My toughest decisions were the case (Mostly because usb 3.0 narrows it down a lot), and the power supply, because I want to have enough power, but there's a good chance I won't use it to the full potential anyway. (As far as gaming and things like that.)
Price range isn't really set, basically, as cheap as possible, but still something really solid..... So here is what I put together, input is great. Sorry to ramble.
Cliffs:
Overall thoughts?
Is it worth getting USB 3.0 on the Mobo AND the Case?
PSU ok?
Heatsink needed?
Processor:
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Motherboard and HDD Combo:
ASRock Z68 EXTREME4 GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.711414
Case and Free Mouse Combo:
COOLER MASTER Storm Enforcer SGC-1000-KWN1 Black SECC / ABS Plastic ATX Mid Tower Computer Case ATX PS2
COOLER MASTER Inferno SGM-4000-KLLN1-GP Wired 4000 dpi Gaming Mouse
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.720116
Heatsink:
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
RAM:
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
Graphics Card:
XFX HD-567X-ZNL3 Radeon HD 5670 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150535
Power Source:
Antec NEO ECO 520C 520W Continuous Power ATX12V v2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030
Optical Drive:
ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Mode
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Wireless Card:
Rosewill RNX-N300 Wireless N Adapter IEEE 802.11b/g/n PCI (1T2R) Up to 300Mbps download and 150 Mbps upload
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166038
Card Reader:
Rosewill RCR-IC002 74-in-1 USB 2.0 3.5" Internal Card Reader w/ USB port
http://www.newegg.com/Product/Product.aspx?Item=N82E16820223109
Final Price:
$818 Shipped
Cliffs:
Overall thoughts?
PSU ok?
Heatsink needed?
Processor:
Heatsink:
RAM:
Graphics Card:
Power Source:
Optical Drive:
Wireless Card:
Card Reader:
Final Price:
$818 Shipped
