First time build advice required
Emmef
5
I am building a system from scratch for the first time, so I have some newbie questions!
CPU is Haswell i5 4670k
Motherboard is gigabyte z87x-oc
My question is do I need a separate cooling fan for the CPU?
That motherboard is rather expensive and for $50 less you can get a board which will do everything just as well. Then you could use the money for a better GPU.
Ah, so if I don't intend to overclock straight away I can forget the additional fan and just buy one when I decide to overclock?
