Hello all
This is my first time building a PC. I would like some advice on the below build that I found on reddit.
1. Would this build be good enough to run modern games on medium/high at 1080p?
2. In terms of future proofing is this build relatively easy to upgrade and how long would a build like this last i.e. how long would it stand the test of time?
3. Would it be possible to switch the mobo out for one that has built-in WiFi and Bluetooth.
4. On reddit it said that the memory would need to be overclocked. Is this easy to do and how would I go about doing this?
General details:
Budget: £800ish
Region: UK
Build: 1080p Gaming
PCPartPicker part list: https://uk.pcpartpicker.com/list/qQFbHh
Price breakdown by merchant: https://uk.pcpartpicker.com/list/qQFbHh/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor (£142.50 @ Aria PC)
Motherboard: *MSI - B450M PRO-VDH Micro ATX AM4 Motherboard (£62.99 @ Amazon UK)
Memory: *Patriot - Viper 4 16 GB (2 x 8 GB) DDR4-3000 Memory (£99.49 @ Amazon UK)
Storage: Crucial - MX500 1 TB 2.5" Solid State Drive (£120.99 @ Aria PC)
Video Card: *XFX - Radeon RX 580 8 GB GTS XXX ED Video Card (£183.59 @ Amazon UK)
Case: *Thermaltake - Versa H21 ATX Mid Tower Case (£36.38 @ Amazon UK)
Power Supply: *SeaSonic - S12II 620 W 80+ Bronze Certified ATX Power Supply (£57.62 @ CCL Computers)
Total: £703.56
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2019-01-31 18:31 GMT+0000
Thank you for your time.
General details:
Budget: £800ish
Region: UK
Build: 1080p Gaming
Total: £703.56
