First Time Build need Opinions.
TheRealBrad
Commendable
Feb 12, 2017
4
So I have never built a PC nor do I have much knowledge when it comes to PC parts so in short I'm just curious if all of these parts are compatible and also wanted to know if their was anything I could enhance while I am at it. The build will be for gaming mostly, I would like to get 1080p at 60 fps or better at maxed settings. I am trying to stay around this price, Thank you in advance for any and all help.
Build is as follows:
-CPU: Intel I 6500
-MoBo: MSI B150M MORTAR Micro ATX LGA1151 Motherboard
-RAM: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory
-Hard Drives: 1TB Wester Digital blue and a Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive
-GPU: XFX Radeon RX 480 4GB RS Video Card
-Case: Thermaltake Versa N21 ATX Mid Tower
-PSU: EVGA 500W 80+ Bronze Certified ATX
I see what you are saying now. Like I said still pretty new to all of this so I appreciate the help. Do you have a specific brand that you would recommend? Honestly I just picked one that was pretty cheap.
Here is the list:
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($189.99 @ SuperBiiz)
Motherboard: Asus H110M-E/M.2 Micro ATX LGA1151 Motherboard ($55.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2133 Memory ($96.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.33 @ OutletPC)
Video Card: EVGA GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card ($379.99 @ Jet)
Case: Corsair 100R ATX Mid Tower Case ($49.99 @ B&H)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply ($49.99 @ B&H)
Total: $872.27
Generated by PCPartPicker 2017-02-13 01:07 EST-0500
This is what you get if you spend $30 extra.
I had the Thermaltake Versa case at one point, the airflow is severely impacted by all those drive cages at the front. Build quality isn't great either, very flimsy feeling plastics and aluminum. Fractal Design Or Phanteks or NZXT make some great open interior designs. Look for a single 5.25 front bay. 500W bronze is a fine power supply. If you can stretch your budget, go for a straight 500gb m.2 ssd build, no hard drive needed; I mean a 16gb usb flash drives are big enough to hold like everything that's not games.
