First time build problem
Lewie1983
4
Hi, I've just finished my first build on my gaming of, all parts are in and wired up with the correct connections.
Turned it on and all fans are running fine, disc drive is working, motherboard light says its on, graphics card fan seems to be running etc, the problem I've having is there is no signal to the monitor, I've tried different connections etc but no luck, any ideas what it could be
Yes I've heard that from a friend but tried the motherboard plugs when I didn't have a signal from the gpu
You cant tell if a mechanical hdd is running or not just by feeling it. When you have power connected to it they tend to vibrate or spinn.
