This is the first time I've built a desktop and while I thought I had everything figured out, I am at the end of my rope here. The issue is low performance on everything. I cannot run games like League of Legends on the lowest settings (I end up with 3-6 fps). The build is as follows:
MOBO:
AsRock B85 Pro4 [BIOS 2.00]
CPU:
Intel core i7-4790 3.6Hz [Driver version unknown, but device manager says up to date]
RAM:
Corsair XMS DDR3 32gb
PSU:
Seasonic G series 550W ATX12v/EPS12v
GPU:
Zodiac GeForce 770 4gb [337.88]
Storage:
1Tb disc storage
I have listed the driver versions above in brackets. As far as I know the entire system is up to date, driver-wise. The cooling is all stock, but according to hwmonitor, msiafterburner and GpuTweak (get to that in a moment) nothing is running above 40C. I had originally thought that the performance issues were due to a bad graphics card (ASUS r7 260x). I chose to return the Asus card and upgrade. I used DisplayDriverUninstaller to wipe the AMD drivers off of my system and installed the new card. The performance issues are the same if not worse with the upgraded card.
I am hoping that someone here just points out something simple that I missed. I cannot figure out why my shiny new computer is performing below my nine year old laptop. Thanks in advance
MOBO:
CPU:
RAM:
PSU:
GPU:
Storage:
1Tb disc storage
