[SOLVED] First time builder and starting from scratch. Does this build sound good, any suggestions? Thanks!
May 14, 2020
Build...
Monitor: ASUS VG278Q 27
Wifi: ASUS PCE-AC56 PCI Wireless Express Adapter
CPU: AMD RYZEN 5 3600X
GPU: Gigabyte GeForce RTX 2060 SUPER GAMING OC 3X
RAM: Crucial Ballistix 16GB (2 x 8GB)
SSD: Samsung 860 QVO 1TB
PSU: Seasonic FOCUS GM-650, 650W
MOBO: MSI Arsenal Gaming B450 Tomahawk Max
Case: Corsair Crystal Series 460X RGB
Extra fans: Corsair ML140 (twin pack)
I don't think I forgot anything, but please let me know if I did (even if it is a small detail).
Does anything here seem overkill? I would like to bring down the cost if I could, without considerably decreasing performance.
Thanks!
Your build is very good.
No need to change a thing.
If you are not too anxious, you might wait and see what intel 10th gen imminent launch brings.
FWIW:
MY build process:
Before anything, while waiting for your parts to be delivered, download
and read, cover to cover your case and motherboard manual.
Buy a #2 magnetic tip philips screwdriver.
I find it handy to buy a power switch like this for testing.
https://www.ebay.com/p/4in1-PC-Powe...or-Computer/631889283?iid=142232821294&chn=ps
1. I assemble the critical parts outside of the case.
That lets me test them for functionality easily.
A wood table or cardboard is fine.
2. Plug in only the necessary parts at first...
FWIW:
MY build process:
2. Plug in only the necessary parts at first. Ram, cpu, cooler, psu.
Do not force anything. Parts fit only one way.
Attach a monitor to the integrated motherboard adapter if you have one, otherwise to the graphics card.
  1. If your motherboard does not have a PWR button, momentarily touch the two pwr front panel pins with a flat blade screwdriver.
  2. Repeatedly hit F2 or DEL, and that should get you into the bios display.
  3. Boot from a cd or usb stick with memtest86 on it. memtest will exercise your ram and cpu functionality.
  4. Install windows.
  5. Install the motherboard cd drivers. Particularly the lan drivers so you can access the internet.
Do not select the easy install option, or you will get a bunch of utilities and trialware that you don't want. Drivers only.
  1. Connect to the internet and install an antivirus program. Microsoft security essentials is free, easy, and unobtrusive.
  2. Install your graphics card and driver if you tested with integrated graphics.
You will need to remove the graphics card later to install your motherboard in the case.
As a tip when screwing the motherboard into the posts, give the screw a small counterclockwise turn until you feel a click.
That lets you know that the screw will engage properly.
Make a note of how the graphics card latches into the pcie slot.
The mechanism will be hidden under the card and may be difficult to work if you have not previously checked how.
  1. Update windows to currency.
  2. Only now do I take apart what I need to and install it in the case.
  3. Now is the time to reinstall your graphics card.
FWIW:
MY build process:
  4. Install windows.
Thank you very much!
