So its going to be the first time i'm going to build a pc and i've found the parts I want to use on PC Part Picker but i dont know if it is all going to work or not
In the compatibility notes it says Some physical dimension restrictions cannot (yet) be automatically checked, such as cpu cooler / RAM clearance with modules using tall heat spreaders. but i dont know if its ok or not.
Can someone help me please?
This is my build in question
https://uk.pcpartpicker.com/user/FunkyPixie/saved/MVnfHx
Thank You
Thank You
