Question First time building a PC. Need advice.
Curesto
40
Hi, i want to build a PC with limited budget in a country with bad economy.
Purposes: 1080p gaming, photoshopping, video editing, rendering and programming. I have 1080p monitor.
The system i'm thinking about building:
CPU: Intel Core i3-12100F
MOBO: MSI Pro H610M-G
MEMORY: Kingston FURY Beast 8GB*2 DDR4 3200MHz
GPU: Sapphire Pulse RX 6700 10GB GDDR6
SSD: Hi-Level GMR3500HS 500GB
PSU: Gigabyte P650B 650W 80+ Bronze(Already have that one)
Case: Aerocool Zauron Saturn
Reactions: Why_Me
Looks good. Crappy motherboard, but if you must compromise somewhere, you did good to fit that GPU in there. I hope you found a good deal on it. It should be more than enough for 1080p gaming. I'd expect to want more drive space at some point.
Thanks. I can get better motherboard as long as it is H610. B660 quite expensive in my country.
