Question First time buying computer parts - advice
Best-Yogurtcloset513
Commendable
Feb 1, 2022
49
14
1,535
Hi everyone!
I'm located on Philippines
and this would be my build
https://pcpartpicker.com/list/Ywg7xs
CPU : AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor
CPU Cooler : Deepcool ASSASSIN III 90.37 CFM CPU Cooler
Motherboard : MSI B550-A PRO ATX AM4 Motherboard
Memory : G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory
Storage : PNY CS3140 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Video Card : Asus DUAL Radeon RX 6700 XT 12 GB Video Card
Case : NZXT H510 Flow ATX Mid Tower Case
Power Supply : SeaSonic FOCUS Plus Platinum 650 W 80+ Platinum Certified Fully Modular ATX Power Supply
Any opinion are most welcome!
i prefer if i can buy any parts you guys recommend on Shopee.ph and my budget are idk since i just gonna buy it piece by piece every month.
PS: I already bought the motherboard since i found it on a promo sale.
New build since suggestion from great people below.
https://pcpartpicker.com/list/66fz3y
CPU : AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor
CPU Cooler : Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler
Memory : G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
Case : darkFlash DK352 ATX Mid Tower Case
Looks good, especially:
Memory : G.Skill Ripjaws V 32 GB (2 x 8 GB) DDR4-3600 CL16 Memory
2x 8GB = 16GB, not 32 GB. Are you getting two sets of 8GB RAM, with total of 4x sticks, to get 32 GB?
"This part list is private."
Oh i forgot about the ram, im supposed to get the 16gb but i changed my mind and changed it to 32gb since i found it cheaper and more practical to my usage. i gonna update the link wait a bit. could you check again?
Since you're getting a decent cooler, is there a reason you're not considering 5800x3D instead?
i did think of this, but 5800x3rd are price like iphone se on our country. and also a bit overkill.
Reactions: boju
Hi everyone!
Nice build ^^ .. have a look at the 5700X.
I did but i though 5800x would be nice since it have more numbers on it. do you think i should just go for 5700x? the price between them are something i can manage if i stay with 5800x but if theres no boost to 5800x then i can go with 5700x.
Assassin III would definitely fit in there.
Do you think its too much for my build with my cpu cooler? should i go with NH-D15S or Peerless Assassin 120 ?
Reactions: Why_Me
The 5700X runs neck and neck with the 5800X while running cooler and it is usually less expensive.
Too much... what, exactly?
Cost? Peerless Assassin 120 can rival the Assassin III for a fraction of the price, but if the cooler isn't available, then it doesn't matter.
D15S is single fan cooler that's shorter than Assassin III, so fits in more cases and ram configs. Probably not much cheaper, as Noctua charges a premium.
I see what you mean by fraction of the price, wow im so surprise how cheap it is, i will change my cpu cooler to peerless assassin 120 then.
i see, maybe i should go with 5700x as you said since its negligible to the benefit i would get from 5800x .
Unless the price is really close, just go with DDR4 3200 CL16. It will perform the same as 3600 CL18.
Actually i bough a G.Skill Ripjaws V 16GB (2x8GB) ddr4-3200 cl16 since i favor the 3600 thing but im planning to refuse the package as it deliver on my doorstep. do you think 16gb is more than enough for gaming nowadays?
Edit: Guys maybe you can suggest some cheap case. it would be great help :)
i found this and it looks LIT!
Darkflash DK210 V.2 (GRAFFITI) PC CASE maybe someone can put some opinion on it?
edit2; i found a suitable case, its Darkflash DK352.
Reactions: Why_Me
