Question First-Time PC Builder – Should I Stick With My Planned Build or Upgrade?
Aug 12, 2025
Hi everyone! 👋
I’m new to the PC building world and this will be my very first custom desktop, so please go easy on me if I sound like a complete beginner. I’ve been using a Dell G3 laptop for the past 4 years (from my college days), and now I finally want to upgrade to a proper gaming PC.
My use case:
  • Gaming (AAA titles + some competitive games)
  • Streaming / binge watching
  • Office work & day-to-day tasks
  • Not much heavy video editing or 3D rendering
I went to a local PC shop with a budget of around $1,800 USD / €1,650 (just for the tower – no peripherals) and here’s the build they suggested:
  • CPU: Intel Core i9-14000K
  • GPU: NVIDIA RTX 5070
  • Motherboard: ASUS TUF Gaming Z790 WiFi
  • RAM: 32 GB DDR5 6000 MHz (2×16 GB)
  • SSD: WD Black 1 TB NVMe
  • PSU: 850 W 80+ Gold
  • CPU Cooler: 360 mm AIO Liquid Cooler
  • Case: ATX Mid Tower
They also offered these upgrades:
  • Intel Core i9-14000KS (+$60)
  • RTX 5070 Ti (+$345 over the RTX 5070)
Since I’m not planning to upgrade my PC for quite a while, I’m wondering:
  • Is it worth stretching the budget for the i9-14000KS and/or RTX 5070 Ti?
  • Or is the original build already balanced for my needs?
  • Would you suggest swapping any parts for better value/performance?
  • Any brands/models you personally recommend for PSU, cooler, case, or RAM?
I’m genuinely excited about building my first PC and would love to hear your thoughts. Thanks in advance for helping out a newbie!
Hi everyone! 👋
My use case:
What country are you located, and do you require a monitor in your budget?
India,Excluding Monitor
The 14900K is a expensive heat producing power hog. Look for a board that supports PCIe 5.0 for the gpu seeing how these new AMD and Nvidia cards support PCIe 5.0. 750W ATX 3.0 / 3.1 psu for the RTX 5070. A set of 2x16GB DDR5-6000 CL30. I'll use these components as a example.
Intel
https://mdcomputers.in/product/asus...rd/intel-chipset-motherboard/z790-motherboard
Asus Prime Z790 P CSM ₹22,785
https://mdcomputers.in/product/inte...ssor/processor/intel-processor/intel-14th-gen
Intel Core i7-14700F ₹27,700
https://mdcomputers.in/product/cpu-...l-ag-series-cpu-air-cooler-r-ag620-bkanmn-g-1
Deepcool Gammaxx AG620 ARGB ₹3,560
https://mdcomputers.in/product/adat...32gb-ddr5-ax5u6000c3016g-dtlabwh/ram/ddr5-ram
ADATA XPG Lancer Blade DDR5-6000 32GB (2x16GB) CL30 ₹10,590
https://mdcomputers.in/product/smps/super-flower-zillion-db-750w-bronze-smps
Super Flower Zillion DB 750W ATX 3.1 80+ Bronze SMPS ₹6,150
AMD
https://mdcomputers.in/product/gigabyte-b850-gaming-x-wifi6e-motherboard
GIGABYTE B850 Gaming X WIFI6E ₹17,000
https://mdcomputers.in/product/amd-...-processor/processor/amd-processor/ryzen-9000
AMD Ryzen 7 9700X ₹30,600
