First Time System Build - Advice Please
pledge42
8
Hi,
I am going to be building a PC soon. Please could you advise me. I am either going to get an 8350, with a good motherboard, or an 4670 with an alright motherboard. What do you think is best, and are there any other good options. You can also advise on a better build. My budget is ~£750-£800. All ill be doing is gaming. I'd linke to get +60fps on most games at ultra.
Here is the rest of the build:
AMD R9 290
600W PSU
1TB HDD
8GB 1866MHz RAM
DVD Drive
Fractal Design Define R5
21.5 inch Monitor
Here's the link: http://uk.pcpartpicker.com/p/6PsYhM
Your link does work you have to post the permalink or use the export button(bbcode). 8350 vs the Intel would depends on the use of the system. For mainly gaming get the Intel. If you plan on doing some gaming but alot of multitasking that will use more than 4 threads then get the AMD.
I've fixed the link. I'm only going to be playing games, along with browsing. No video editing really.
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor (£149.15 @ Aria PC)
Motherboard: Gigabyte GA-H97-D3H ATX LGA1150 Motherboard (£75.54 @ Aria PC)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory (£57.60 @ Kustom PCs)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£40.39 @ Aria PC)
Video Card: Asus Radeon R9 290 4GB DirectCU II Video Card (£215.00 @ Amazon UK)
Case: Fractal Design Define R5 ATX Mid Tower Case (£89.99 @ Amazon UK)
Power Supply: XFX 650W 80+ Bronze Certified Semi-Modular ATX Power Supply (£61.00 @ CCL Computers)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer (£10.46 @ Aria PC)
Monitor: Hannspree HE225DPB 21.5" Monitor (£79.61 @ Ebuyer)
Wireless Network Adapter: TP-Link TL-WN781ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter (£7.54 @ CCL Computers)
Keyboard: Logitech K120 - UK Layout Wired Standard Keyboard (£11.52 @ Amazon UK)
Total: £797.80
Generated by PCPartPicker 2015-01-10 19:51 GMT+0000
Do you think the CPU will be good enough for the future?
It's one of the better gaming cpus currently available.
Yes... The i5-4590 is pretty much a new generation.
