[SOLVED] First time using an electric blower
you def want to hold the fans when blowing out the dust. a finger works as does a pencil gently put into place to keep the blades still.
the air can spin the fans much higher than they are rated to spin. this will damage them of course and cause them to fail, if not right away but down the line. using the blower is not a bad idea, but do take care all the fans are taken care of.
also note to be careful with the wand as you go about the cleaning. it is easy to go nuts and smack about inside the case possibly damaging a part or 2. not massive concern but don't look away while wildly swinging the wand about inside the case :)
Reactions: Temps and CountMike
