FIrst Water cooled custom loop and I'm having a few pump concerns
Candan
237
Hey all
So I'm as far as filling the loop with water. This is my first ever custom loop and I went with hard tubing and no leaks! (so far!)
So... The pump drew some water in and filled most of the loop. Gurgle, gurgle
Now everything is full except the very last piece of pipe from the rad back to the reservoir/pump. You can see in the pic.
Now, I just don't know what's happening with the last section of air. It won't come out. The pump has been running for about 6 hours.
The water in the first section of pipe and the water in the reservoir is a little warm now, so this tells me that nothing is pumping. Actually, it's trickling inside the tube, but literally trickling...
I've rocked rolled, tipped and shook it. With the reservoir seal on and off. Nothing has helped.
Please help
https://photos.app.goo.gl/ExSMFBPFTtEx2hOE3
The funny thing is that faalin's description of the XSPC D5 matches the Vario (the one with 3 pin connector and speed dial on the pump).
The PWM variant has no dial, molex (yellow and black wires) and 4pin fan connector (green - PWM and blue - sensing wires).
And that Vario pump really does not require the fan connector to be plugged. Everything I said, is relevant only for PWM variant. Even then it really not for all models. From what I see, newer models are running at 100% without PWM signal.
Anyway, laying the case on the side, should have pushed most of the air into the res. once you have the flow, you can put it back to be standing and add liquid to the res. repeat tilting if necessary.
That's exactly what the problem was.
Once I turned the base plate to allow the pass over the fins. Upon refilling the loop, all the bubbles were sucked out like a vacuum and temps are now 28C idle and 50-55C under load.
Love it! Working as it should.
