Five 3-pin fans, all running full speed. How do I control?
JigoroKano
Commendable
Nov 30, 2016
37
My motherboard has one CPU fan and one other fan header. I bought a silverstone fan distributor that takes a SATA power and all the fans plug into it, but now they all run full blast. I have a free 5 1/4 bay. Can someone direct me to the correct device that will let me control the fan speeds? When I look at the fan speed controllers with knobs, most of the descriptions say they will only work with 4-pin PWM fans. I just want to make sure I get something that will work so an actual product link would be appreciated. Need to control 5 fans.
https://www.amazon.com/gp/product/B00VNW556I/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
The PWM fan hub will only work in tandem with PWM fans. If you connect 3 pin fans to the fan hub they're only receiving the full power thus the full blast. You can at this point look at fan controllers that accept 3 pin fans since 3 pin fans are voltage regulated as opposed to PWM fans that are regulated with a PWM signal and a sense wire.
one of the connectors on the fan hub is meant to be used with a cable, that goes to the mainboard, that way, the mainboard controls the fan speed as one fan but the hub feeds electrically all the fans connected
http://silverstonetek.com/product.php?pid=526&area=en
this one to the motherboard system fan connector
