Quite so; in fact, quite a few people making similar comments here seem to not understand that the PSU will not "push" more power into the system if that is not demanded by that system. If your configuration requires only 350W max, that's how much will be provided by the PSU.@blackmagnum
Well, you don't seem to understand fully.
They don't really consume more power than the connected hardware demands. On the other hand, they have an amazing efficiency rating, meaning that they use a minimum of power, and are therefore better for the planet. 😉
@blackmagnum
That being said, the forum is full of PCs crashing upon launching certain programs, launching the OS or even upon booting up, and more often than not this unstable behavior is due to underspec'd PSUs that can not keep up with a sudden increase in wattage demand. Just because a PSU is barely meeting the power rating of your system doesn't mean it will be able to sustain that for any given amount of time.
I, for one, would rather have redundancy built in that can cope not only with current configuration, but also with foreseeable upgrades.
I know it can happen but I’ve never seen it. It’s always something else. If the power supply is suspect then you just unplug everything that you don’t need. If you do that and are still unstable then it’s not the PS. If you unplug everything you don’t need and your are still within a few hundred watts of the PS max then maybe.
I’ve always had way more PS than needed and that never stops all the PCs I’ve have crashing for all kinds of other reasons. Mostly video drivers.
I still like the interior of my Antec TruePower Quattro 850w. Massive heatsinks!
About that Antec 1300w PSU, according to their site, it says that has a "20+8-pin MBU socket for the needs of tomorrow."
Do you guys have any info on this?
http://store.antec.com/highcurrentpro/hcp-1300-platinum.html
