Tsaf Jul 22, 2020 1 0 10 Jul 22, 2020 #1 I got a new processor so I needed to update my bios before I could use it. When a went to update it it flashed the bios update file then right after it said could not find file
Solution G G glennhl Jul 22, 2020 Thumb drive must be formatted FAT32. I've also seen cases where the Thumb Drive was bad, may need to try another one.
Barty1884 Retired Moderator Apr 16, 2015 22,254 1,355 108,740 Jul 22, 2020 #2 Right after what? A reboot? Or when it was loading into the flash drive? Was the flash drive formatted correctly? Did you place the BIOS file in the correct location, as per the MB vendors 'how to'? Upvote 0 Downvote
G glennhl Prominent Jul 2, 2020 50 4 545 Jul 22, 2020 Solution #3 Thumb drive must be formatted FAT32. I've also seen cases where the Thumb Drive was bad, may need to try another one. Upvote 0 Downvote Solution
