P prkundan Prominent May 2, 2019 59 0 530 Oct 6, 2020 #1 I once inserted my flash drive in my PC. I got a message to format it. I ignored it. Now whenever I insert the flash drive it is not detected by the PC. What should do?
Solution SteveRX4 Oct 6, 2020 If other flash drives work OK, then buy another flash drive. Try it on another PC.
SteveRX4 Notable BANNED Sep 29, 2020 1,468 135 890 Oct 6, 2020 Solution #2 If other flash drives work OK, then buy another flash drive. Try it on another PC. Upvote 0 Downvote Solution
SteveRX4 Notable BANNED Sep 29, 2020 1,468 135 890 Oct 8, 2020 #4 No worries. Good luck. Show as SOLVED. Upvote 0 Downvote
