Happy Halloween everybody, got a question for y'all.
In december of last year I built a PC that uses the CoolerMaster ML240L AIO.
I was tinkering inside the case last night to manage cables a bit better when I noticed the blades on the radiator fans have some sort of moisture on them:
It's not particularly sticky, apparently thick enough to catch dust, and If it were plain water condensation I'm sure I would have had a short by now.
Are there case fans that contain lubricating fluid that could possibly leak out? The radiator itself looks dry, so I'm not sure if its a leak from there.
For an idea of it's orientation, the rad is screwed to the roof of the case with fans pushing air out through it. Any help is appreciated.
