if at best you got the vid card g210 NVidia it only supports up to shadier model 4.1
Full Microsoft® DirectX® 10.1 Support
DirectX 10.1 GPU with full Shader Model 4.1 support delivers unparalleled levels of graphics realism and film-quality effects.
and then if you just use the onboard only is good to shadier model 3.0
Microsoft® DirectX® 9.0 Shader Model 3.0 Support
Ensures top-notch compatibility and performance for all DirectX 9.0 applications, including Shader Model 3.0 titles...
Shader Model 5.1 is functionally very similar to Shader Model 5, the main change is more flexibility in resource selection by allowing indexing of arrays of descriptors from within a shader.
what game ? whats the issue ?? whats your system specs ? cant try to answer with out any info on anything going on .. my crystal ball is broken [though its trying to say you maybe using a AMD card ? ]
The game im trying to play is Xenoverse 2. The issue is when i try to run it, it shows a message which is Fatal Error, Shader model 5.0 is required. My specs is in this link http://prntscr.com/d48csi
so you need new up to date stuff to support the game with shader model 5.0 or higher
this is a hardware limitation and can not be fixed you would need a new vid card with shader model 5.0 or above
