My new builds (witch to get?):
AMD ADO4600CUBOX - Athlon 64X2 4600+ (2400 MHz), Socket AM2, 512KB x2, Boxed, 65W
MB Gigabyte GA-M55S-S3, nForce 550, S-AM2, ATX 24p., PCI-E x16 / 2xPCI / 4xPCI-x / Dual DDR2-800, SATAII Raid, SB 8ch.&1394&Lan on board.
2*TwinMOS 8D25KK-TW - DDR II 1024 MB PC6400, 800MHz, SPD 5-5-5-15, 1.9~2.0V, PCB cu 6 straturi, Black Heatspreader, Ambalaj retail
HDD SAMSUNG 320 GB 7200rpm 16Mb Serial-ATA II 300 HD321KJ with NCQ
FDD ALPS 3,5i BLACK
DVD+/-RW ASUS DRW-1814BLT-B Lightscribe - 8X18X8X16X - 48X32X48X Serial-ATA BULK Dual Layer BLACK
NX88S320H-B-RH, nVidia GeForce 8800GTS, PCI-E, 320MB, 320 bit, DDRIII, TV-Out, DVI-I, TwinView, Fan, Core 500MHz, Mem 1600MHz
BlackFin II, otel, neagra, Front USB & Audio, ventilator 12cm, SP-2709B, Speeze
Thermaltake W0062RE - Sursa ATX 12V v2.0 * Putere: 420W * Linii: 2x12V * PFC: N/A * Ventilator: 12cm - 2000 RPM(+/-10%) * Conectori: alimentare 24 pini (20+4), 1 x 8 pini, 1 x 6 pini (PCIE), 8 x molex 4 pini, 2 x FDD, 2 x SATA * Eficienta: 70% * Sleeving pt cabluri: DA * Protectie: supratensiune, subtensiune, scurt-circuit * Extra: Mirror Coating
_____________________________________________________________________ ________________________
Intel BX80557E6750 - Pentium4 Core™2 Duo E6750 2670 MHz, Socket 775, 4MB, FSB 1333 Boxed, 64 biti
GIGABYTE Intel P35, s.775, FSB 1333, LAN, SATA 2, PCI-E, Dual DDR2, ATX, P35-DS3
FDD ALPS 3,5i BLACK
Sapphire Radeon X1950 PRO 256MB GDDR3 PCI-E Dual DVI / TVO ; Single Slot; Fan w/ Heatsink plus ram sink
CASE UTT - MacaLink A-2656-2C (Aqua) LCB-450W ATX 420(H)x180(W)x440(D) Black USB + Audio TAC
Thermaltake W0062RE - Sursa ATX 12V v2.0 * Putere: 420W * Linii: 2x12V * PFC: N/A * Ventilator: 12cm - 2000 RPM(+/-10%) * Conectori: alimentare 24 pini (20+4), 1 x 8 pini, 1 x 6 pini (PCIE), 8 x molex 4 pini, 2 x FDD, 2 x SATA * Eficienta: 70% * Sleeving pt cabluri: DA * Protectie: supratensiune, subtensiune, scurt-circuit * Extra: Mirror Coating - 119.30
950 USD both are the seem price
Is everything ok with it, witch is best, not planing upgrades for a year.
FDD ALPS 3,5i BLACK
FDD ALPS 3,5i BLACK
