Question Forbidden west running barely in 35 fps in gtx 1650 super + FSR 3.1 and frame generation on !
11
I have a gtx 1650 super paired with i5 10400f and 16gb ram ddr4 , According to many youtube videos I saw Horizon forbidden west with the latest fsr3.1 Should run with 55+ fps with frame generation on in my PC with medium settings.I installed the game today but It gives barely 30+ fps with low settings and frame generation on . I have updated my motherboard bios and gpu drivers . Nothing is working . Can anyone help me to fix this issue
The youtuber's :
CPU: AMD Ryzen 5 5600G 3.9GHz (Boost 4.4GHz)CPU Cooler : AMD Wraith Stealth (Stock)RAM: Kingston FURY Beast 16GB (8x2) 3200MHz DRR4MOBO: ASROCK Fatality AB350 Gaming K4VGA: EVGA GeForce GTX 1650 SUPER SC ULTRA GAMING 4GB GDDR6SSD: KINGSTON 2.5" 120GBSSD2: Team Group NVMe 256GBHDD: WD Blue 2TB 7200RPMHDD2: WD Blue 2TB 7200RPMHDD3: WD Blue 500GB 5400RPMPSU: Corsair CX650M 650W 80plus BronzeCase: Cube Gaming WeissMonitor: SAMSUNG S22F350OS: Windows 10 PRO Version 21H2 (OS Build 19044.2364)Nvidia Geforce Game Ready Driver : 551.86
My config:
1 > i5 10400F 4.2 ghz boost
2 > gigabyte gtx 1650 super oc
3 > single channel 16gb ddr4 ram
4 > 450watt collermaster psu
5 > 256gb ssd consistent
6 > windows 11 64 bit
Single channel DRAM is a pretty big problem. I believe they also recommend using a SSD for storage on that game.
Generally speaking though if lower settings/upscaling/frame generation aren't helping your performance it's CPU limited which would point at your memory configuration.
Reactions: Phaaze88
RAM is normally sold in matched pairs that are designed to work together. You can buy what appears to be an identical stick but it may have had some changes - normally memory chip manufacturer (Hynix, Samsung etc) and may or may not work. It is a gamble. Corsair vengeance sticks are notorious for it. The revision often indicates this.
I would personally look at getting a matched pair if you can. DDR4 is quite cheap now for a 2 x 8gb kit and you could always try and sell your current stick to get a bit of money back.
1 stick of16gb or 2x8 of ram that's important 1 stick will cut your performance in half
Games like bandwidth 1 stick is only 1 channel
If your ram has 4 slots and you have 2 sticks make sure they are in slots 2 and 4 2 being from the CPU cooler and 4 being last.
I would personally buy 2 sticks of ram 16gbx2 at 3200/ cl16
Reactions: MEMOFLEX
My motherboard has only 2 slots , moreover it supports upto 2666 mghz . So is their any discripancy about which one to plug in which slot ?
