I have just installed Win2k on a new system and i partitioned an 80 gig ata100 drive into a 20 gig c: and 60 gig d:
Now that WIn2k is installed, i want to format d: so i can use it but i get errors when i try. It says that it can't format it or that volume size is to big. Does this mean that i have to split the d: again because it larger than 32 gigs? Or is there a way of formating with a 60 partition? I used fat32 for the c: and want to use it also for d:
And another thing. I read somwhere that win2k doesn't support ata-100 drives?
thnx in advance.
thnx in advance.
, once at the command line (A: prompt), type FORMAT D:, and type "Y" and hit Enter, when asked if you wish to actually format the partition. Since the partition is 60GB, the format will automatically use the FAT32 file system.
