Fortnite Battle Royale has a long list of weapons, and all of them are useful to some extent. One of the most useful weapons in Fortnite Battle Royale is the Scar. It comes in two variants; the purple and the gold and both of them are great. To know more about the gun, look at the guide below:
Grab It Quickly:
The Scar assault rifle is indeed the bigger and better version of the M16, but with that, it is also very hard to find the Scar. You cannot just go ahead, kill an enemy and luckily find a scar in their loot (Although it can happen) It is pretty hard to find so there is a good chance that your enemies will not have the Scar as well. Also, it is not easily found in the chests as well.
So you will have to open quite a few chests before you see one. Remember, you will not find it anywhere else besides the chests or in the loot of the enemy (Who would have gotten it from a chest). So if you see a scar either in the loot of an enemy or in a chest, don’t think for a second and grab it in a heartbeat. It is likely that you may not see it again for a long time.
Very Powerful:
There is no denying to the fact that Scar is a very powerful weapon but what you don’t know is that it is the most powerful weapon in all assault rifles. And it will be most effective if you use it at the medium range. It will simply blow your opponents. You can also use the combo of a Scar and a Shotgun and your enemies will not stand a chance in front of you. Just make sure to use it in tough situations and save it for the end as you may run out of ammo if you use it for every other enemy
you see.
First Shot Accuracy:
There is a feature in Fortnite that is called first shot accuracy. If you are not sure about it then what it does is if you line up your aim with an enemy and you are not moving and you also haven’t fired the weapon recently, then your first shot will hit the target for sure. This has made it a lot easier to fire accurate first shots with the Scar. Just line up your weapon, hold for a few seconds and fire the shot, you are likely to hit on the target.
Low Recoil:
According to some big gamers, who have been testing the Scar, it has very low recoil that is near to zero. So if you are using the Scar, you don’t have to worry about missing your shots due to high recoil. But even if you notice some recoil in the Scar, you can always fire in small bursts and that will further reduce the recoil of the weapon.
This is all there is to this beast. The gun is definitely a great addition to the game and the good thing is that its golden and purple variants don’t have much difference in damage and other things so it is okay if you get the purple one.
