It is a very simple structure that can work great for saving you from taking damage. You just need a small amount of resource to build it and it can give you a quick cover from the fire. To make it properly, see the guide below:
Why You Need It?
It is a great way to quickly put up a defence and save yourself from the enemy who is coming at you with aggression. It is really simple and may save your life. Furthermore, it may give you an advantage over your enemies as you can shoot them from a cover while they are in the open unless they build one for themselves as well. You can use in a lot of different ways to either trick your enemies into thinking you are behind it, while you are running away or to save yourself from the damage of their bullets.
When to Use It?
Building panic walls can save you from a lot of trouble and you may even end up winning the combat. You can use it if you are running out in the open and suddenly someone shoots at you from behind; now instead of finding them and then attacking them, you can just build panic walls and then work on finding them. Similarly, you can build the panic walls if you encounter an enemy directly ahead of you and you want to fight them strategically instead of opening straight fire them you can build panic walls and shoot at them while taking cover.
How to Use It?
You can use the panic walls in two ways. You can use them to absorb bullets coming from the enemy while you are running in the other direction. This way, your enemy will not run behind you as he will think that you are behind the walls while you are getting away. Secondly, you can use the panic walls by placing them in front of you while facing the opponent to minimize the damage and then pop out from behind it to attack them.
How to Build It?
When you are about to build the panic walls, then make sure to opt for wood as it is common and disposable resource. Also, wood is not liable to break as easily as brick or metal when it is first placed. This makes wood a must to use resource when you are planting down in a hurry.
Select the default walls and then place them in front of your or swivel and place them on your sides or behind according to the need. This means place them from where you are taking damage or an enemy is coming.
Panic walls are a great way to defend yourself from incoming fire or enemies. You can save yourself from any direction you want as you just need to swivel and place the wall. Make sure to understand how it is used, which resource to use and how to place the wall before you try them in the battle.
Why You Need It?
![1wKxHnE.png](https://i.imgur.com/1wKxHnE.png)
When to Use It?
![jtAL8au.png](https://i.imgur.com/jtAL8au.png)
How to Use It?
![qZxcbc5.png](https://i.imgur.com/qZxcbc5.png)
How to Build It?
![lcyh53P.png](https://i.imgur.com/lcyh53P.png)
![GWlHzSG.png](https://i.imgur.com/GWlHzSG.png)
