If you want to get a good altitude at a random location where there are no buildings then building a sniper tower is your way to go. A sniper tower is a perfect structure and can be utilized in a number of ways.
You can get all of the information about this tower and how to build it in the guide below:
Why You Need It?
When you have a sniper rifle and you want to use it at a place that has no vantage point then you will be needing a sniper tower that you can create by yourself. A sniper tower is perfect to give you a vantage point that you can use to take out enemies due to the advantage of height. Also, a good sniper tower will give you cover so you are not easily shot down by an enemy when you are busy taking out other enemies.
When You Use It?
The sniper tower is perfect for three purposes. The first one is when you want to take out enemies through sniping, and you don’t see a point of height. You can then create your own sniper tower. Secondly, you can use the sniper tower to see the surrounding area from a view of birds-eye. This will help you locate enemies that are near you or maybe some chests that cannot be seen from the ground level. Lastly, if you want a good area to cover yourself while you are either snipping enemies or you are fighting them with any other gun, then it will provide you with a good cover.
How to Use It?
It is pretty easy to use a sniper tower, all you need to do is go to the top and then start looking out for enemies that are near you. You can then either take them out or plan your strategy according to their position. Also, it will give you a height advantage that would be very helpful for you if you want to engage with an enemy as having a height increases your chances of winning a fight.
How to Build It?
Building a sniper tower is really simple. You first need to build a small box while you are inside the box. Then you need to stand at one side and then jump and quickly place a ramp that will be leading upwards. Now move to the top point of the ramp and then build walls encasing yourself. Again, jump up and place the ramp beneath you. Now go to the top point and place walls and repeat the whole process until you reach a height that is perfect for you to snipe down enemies or scout the whole area.
The structure can be used in a number of different ways. You can scale it to as much height as you want. You can start building platforms towards a previously inaccessible area or go about building sky fortress. Also, make sure that you have an escape plan when you are building this tower. It is recommended that you have ramp that leads you downwards from the top so you can quickly begin to come down if other players start damaging your tower.
![UhFPvOx.png](https://i.imgur.com/UhFPvOx.png)
Why You Need It?
![6kbzUSN.png](https://i.imgur.com/6kbzUSN.png)
When You Use It?
![wkU8cCX.png](https://i.imgur.com/wkU8cCX.png)
How to Use It?
![lbZqAHP.png](https://i.imgur.com/lbZqAHP.png)
How to Build It?
![JHVaPdT.png](https://i.imgur.com/JHVaPdT.png)
