Tomato Town is located on the north side of the map. It is at the south-east of the Anarchy Acres and to the northeast of Dusty Divot. The area is a small town that has a gas station and a fast food restaurant.
If you want to land there and dominate, then you should take a look at the below-given tips:
You Can Get Some Enemies:
Tomato Town is a popular spot and that means you can find some enemies lurking around. What you need to do if you are landing here is to look around you to make sure there are no enemies landing where you are landing or else, they will either start to fight you with an ax or may grab a gun before you and kill you. So it is always best to keep your eyes and ears open in this area if you want to survive here.
Check Restaurant and Gas Station:
If you are not sure where to go to get the loot just head straight to the restaurant. You will find good amount of loot there. Also, if you go behind the counter of the restaurant, you will find a chest there. Also, go to the small gas station as well, search it and there is a chance that you will find a chest or some decent amount of loot there.
Plenty of Metal:
The best thing about tomato town is that it has a lot of cars and that means a lot of metal to mine. But the first thing that you need to do is to grab a weapon and then head for the cars to mine the metal. Also, make sure to take a good look around to see if anybody is already there. Once you are satisfied, go ahead and mine the metal. Just remember one thing, some cars may activate the alarms and that can alert other players, so as soon as you hear one, run to the other side.
Wall in the Tunnel:
Now many players know about this and it is a great place to open some chests. There is a tunnel to the south of tomato town. As you go through the tunnel, you will pass a car to your left and then you will come across a red car to your right, the wall right next to the red car can be broken down with the pick-axe. On the other side of that wall, you will find two chests.
Metal Bunker:
To the south of the Tomato Town, there is a metal bunker that has a staircase leading down inside the hill. It will spit you out in a tunnel that will lead you out of the town. The staircase will have two or three weapons on it. You can nab those weapons and may also find a chest at the bottom of the stairs.
If you implement of the tips mentioned above, you will be doing better than the players who do not have much info about this map and that way you will have the edge over them.
Plenty of Metal:
Wall in the Tunnel:
Metal Bunker:
