Classical Commendable Jan 15, 2017 31 0 1,540 Jul 22, 2017 #1 I have gone to Disk Management after I plug my second HDD into my PC, but nothing comes up. What do I do?
Solution USAFRet Jul 22, 2017 Classical : USAFRet : Classical : USAFRet : Classical : USAFRet : Classical : https://gyazo.com/3529c0633f63a5050b3344816c2bd40b And yes, it is a desktop. Disk 0 and Disk 1. What options does it give you when you Right click on the space to the left where it says "Offline" ? The only option was to turn it on https://gyazo.com/81e99ff15f5f5a882593b8ad46b729ca OK...so now it is 'Online'. What did you do next? Well I turned it on and now it's working. I feel really dumb lol https://gyazo.com/20d33a045f9a3d30c78ad2e209d60660 Thanks for the help bro. Still not 100% correct. Another sscreencap of your Disk Management window, please. You need to remove the E drive letter from that System Reserved partition. I merged the two sections of my secondary HDD...
USAFRet Titan Moderator Mar 16, 2013 179,753 22,096 184,590 Jul 22, 2017 #2 Classical : I have gone to Disk Management after I plug my second HDD into my PC, but nothing comes up. What do I do? Assuming this is a desktop: 1. Verify both cables are connected properly 2. Show us a screencap of your Disk Management window Upvote 0 Downvote
Classical Commendable Jan 15, 2017 31 0 1,540 Jul 22, 2017 #3 USAFRet : Classical : I have gone to Disk Management after I plug my second HDD into my PC, but nothing comes up. What do I do? Assuming this is a desktop: 1. Verify both cables are connected properly 2. Show us a screencap of your Disk Management window https://gyazo.com/3529c0633f63a5050b3344816c2bd40b And yes, it is a desktop. Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,753 22,096 184,590 Jul 22, 2017 #4 Classical : https://gyazo.com/3529c0633f63a5050b3344816c2bd40b And yes, it is a desktop. Disk 0 and Disk 1. What options does it give you when you Right click on the space to the left where it says "Offline" ? Upvote 0 Downvote
Classical Commendable Jan 15, 2017 31 0 1,540 Jul 22, 2017 #5 USAFRet : Classical : https://gyazo.com/3529c0633f63a5050b3344816c2bd40b And yes, it is a desktop. Disk 0 and Disk 1. What options does it give you when you Right click on the space to the left where it says "Offline" ? The only option was to turn it on https://gyazo.com/81e99ff15f5f5a882593b8ad46b729ca Upvote 0 Downvote
Classical Commendable Jan 15, 2017 31 0 1,540 Jul 22, 2017 #6 Wait a minute... https://gyazo.com/8e5942a53adc5a93b65dde3311a2d5c8 Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,753 22,096 184,590 Jul 22, 2017 #7 Classical : USAFRet : Classical : https://gyazo.com/3529c0633f63a5050b3344816c2bd40b And yes, it is a desktop. Disk 0 and Disk 1. What options does it give you when you Right click on the space to the left where it says "Offline" ? The only option was to turn it on https://gyazo.com/81e99ff15f5f5a882593b8ad46b729ca OK...so now it is 'Online'. What did you do next? Upvote 0 Downvote
Classical Commendable Jan 15, 2017 31 0 1,540 Jul 22, 2017 #8 USAFRet : Classical : USAFRet : Classical : https://gyazo.com/3529c0633f63a5050b3344816c2bd40b And yes, it is a desktop. Disk 0 and Disk 1. What options does it give you when you Right click on the space to the left where it says "Offline" ? The only option was to turn it on https://gyazo.com/81e99ff15f5f5a882593b8ad46b729ca OK...so now it is 'Online'. What did you do next? Well I turned it on and now it's working. I feel really dumb lol https://gyazo.com/20d33a045f9a3d30c78ad2e209d60660 Thanks for the help bro. Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,753 22,096 184,590 Jul 22, 2017 #9 Classical : USAFRet : Classical : USAFRet : Classical : https://gyazo.com/3529c0633f63a5050b3344816c2bd40b And yes, it is a desktop. Disk 0 and Disk 1. What options does it give you when you Right click on the space to the left where it says "Offline" ? The only option was to turn it on https://gyazo.com/81e99ff15f5f5a882593b8ad46b729ca OK...so now it is 'Online'. What did you do next? Well I turned it on and now it's working. I feel really dumb lol https://gyazo.com/20d33a045f9a3d30c78ad2e209d60660 Thanks for the help bro. Still not 100% correct. Another sscreencap of your Disk Management window, please. You need to remove the E drive letter from that System Reserved partition. Upvote 0 Downvote
Classical Commendable Jan 15, 2017 31 0 1,540 Jul 22, 2017 #10 USAFRet : Classical : USAFRet : Classical : USAFRet : Classical : https://gyazo.com/3529c0633f63a5050b3344816c2bd40b And yes, it is a desktop. Disk 0 and Disk 1. What options does it give you when you Right click on the space to the left where it says "Offline" ? The only option was to turn it on https://gyazo.com/81e99ff15f5f5a882593b8ad46b729ca OK...so now it is 'Online'. What did you do next? Well I turned it on and now it's working. I feel really dumb lol https://gyazo.com/20d33a045f9a3d30c78ad2e209d60660 Thanks for the help bro. Still not 100% correct. Another sscreencap of your Disk Management window, please. You need to remove the E drive letter from that System Reserved partition. I merged the two sections of my secondary HDD https://gyazo.com/4f1b302318ec5d24fe0bd5f65369433c Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,753 22,096 184,590 Jul 22, 2017 Solution #11 Classical : USAFRet : Classical : USAFRet : Classical : USAFRet : Classical : https://gyazo.com/3529c0633f63a5050b3344816c2bd40b And yes, it is a desktop. Disk 0 and Disk 1. What options does it give you when you Right click on the space to the left where it says "Offline" ? The only option was to turn it on https://gyazo.com/81e99ff15f5f5a882593b8ad46b729ca OK...so now it is 'Online'. What did you do next? Well I turned it on and now it's working. I feel really dumb lol https://gyazo.com/20d33a045f9a3d30c78ad2e209d60660 Thanks for the help bro. Still not 100% correct. Another sscreencap of your Disk Management window, please. You need to remove the E drive letter from that System Reserved partition. I merged the two sections of my secondary HDD https://gyazo.com/4f1b302318ec5d24fe0bd5f65369433c Remove the E drive letter from that partition, and you're all set. Upvote 0 Downvote Solution
Classical Commendable Jan 15, 2017 31 0 1,540 Jul 22, 2017 #12 USAFRet : Classical : USAFRet : Classical : USAFRet : Classical : USAFRet : Classical : https://gyazo.com/3529c0633f63a5050b3344816c2bd40b And yes, it is a desktop. Disk 0 and Disk 1. What options does it give you when you Right click on the space to the left where it says "Offline" ? The only option was to turn it on https://gyazo.com/81e99ff15f5f5a882593b8ad46b729ca OK...so now it is 'Online'. What did you do next? Well I turned it on and now it's working. I feel really dumb lol https://gyazo.com/20d33a045f9a3d30c78ad2e209d60660 Thanks for the help bro. Still not 100% correct. Another sscreencap of your Disk Management window, please. You need to remove the E drive letter from that System Reserved partition. I merged the two sections of my secondary HDD https://gyazo.com/4f1b302318ec5d24fe0bd5f65369433c Remove the E drive letter from that partition, and you're all set. thanks a lot mate. Finally have that extra space I need haha Upvote 0 Downvote
