On my old server which I've run Minecraft on for two years now, I've finally shut that down, and am now starting three FPS servers (or trying to) - CoD4, Four Delta One MW2, and Urban Terror... CoD4 is meant to be running though 28960, MW2 through 28961, and UrT through 27960... Although the Four Delta One server seems to be binding to ports and connecting properly, the other two don't. I've tried running the CoD4 server through 28961 as well, but it doesn't seem to show through there either, even though MW2 does. The error is
'WARNING: UDP_OpenSocket: bind: WSAEADDRNOTAVAIL'
on both servers.... The ports are definitely forwarded... Any ideas as to why that is?
If you want to see the shortcut configs, here...
CoD4:
"C:\Program Files (x86)\Activision\Call of Duty 4 - Modern Warfare\iw3mp.exe" +set dedicated 2 +set net_port 28960 +set sv_punkbuster 1 +exec mp-server.cfg +map_rotate +set net_ip 202.126.198.6
Urban Terror:
"C:\Program Files (x86)\UrbanTerror\ioUrTded.exe" +set fs_game q3ut4 +set dedicated 2 +set net_ip 202.126.198.6 +set com_hunkmegs 256 +set sv_maxclients 24 +exec server.cfg
FourDeltaOne:
C:\Users\Administrator\AppData\Local\IW4M\LaunchIW4M.exe +set party_maxplayers 18 +set net_port 28961 +exec server.cfg +map mp_rust +map_rotate -dedicated -console
Yet none of them work... Can't really work out what I've done wrong here.... Thanks for any help.
CoD4:
Urban Terror:
FourDeltaOne:
