Hello,
I own a Samsung C24F396FHU monitor, running at 72hz.
My graphics card is RX 580 8GB.
Will be smart, to caps FPS for a game (ex. Call of Duty) from AMD Radeon settings at 70FPS, enable Freesync and disable V-Sync (both in AMD Radeon settings and in-game menu) to avoid extra input lag?
Is this the best way to play games in whose i reach 90 FPS uncapped? Because using V-Sync make it smooth in 72FPS, but adds input lag, and if i will not use V-Sync, gameplay isn't smooth and i have tearing. What's the point to have 90FPS as long as my 72HZ monitor will always display 72FPS?
Also what's the best configuration for using Chill and Enhanced Sync technologies? I have read so many articles (also contacted AMD and Sapphire), but not a clear answer.
Extra Question: If i had an 144HZ monitor, i could leave V-sync OFF, Freesync OFF and i could get a smooth gameplay as long as all FPS will be displayed in right time? All these technologies are needed for lower-Hz monitors to make them produce a smooth gameplay?
Thank you.
Thank you.
