fps drop and usage drop
Baha__arafat
22
i'm facing a fps drop in most games and low performance with my gtx 1060 3gb manli edition
for example i got fps drop from 70 to 30 in bf1 and from 60 to 20 in watch dogs 2 even in the lowest setting i got fps drop what should i do please help me !!
my spec:
i7 4790 3.6 ghz
ram 8gb ddr3 1600
hdd: 1tb
psu: 600watt (solid atx) 240volt
gpu temps and cpu temps are around 60c
gpu uage is 90 and suddenly drop to 70 and 60
(not stable)
but cpu usage is around 70-75 (semi stable)
i have downloaded the latest nvidia driver 378.49
Kay so... first clearly uninstall ALL existent nvidia drivers incluiding Gforce Experience in Safe mode, Then download Geforce Experience alone and let Geforce experience smartly picks the best and most updated driver that suits with the GPU you currently have.
Once you do this then proceed to download MSI after burner and check the Power Limit its on 100%.
i have tried this method brfore
