I suspect its the CPU!
So i bought this computer with the information that it should be able to run csgo smooth. i have a 144 hz monitor as well, but im only having around 100-120 fps with alot of fps drops and laggy tendencies, this takes the smoothness away and therefore the actual joy of playing. I really want everything in csgo to be butter smooth, and im willing to do whatever it takes.. so community my question is, do i need to replace some hardware in my pc, or are my speccs good enough, just me making mistakes or blocking something?
Seeking help!
CPU: Intel(R) Core(TM) i5-6402P CPU @ 2.80GHz 2.80GHz (Skylake 14nm Technology)
Motherboard: ASUSTeK COMPUTER INC. B150M-A (LGA1151)
Ram: 8,00 GB
SSD/HDD: 223GB SanDisk SDSSDA240G (SATA (SSD))
GPU: NVIDIA GeForce GTX 1060 6GB
PSU: Model no: RS-500-ACAB-B1
Chassis: unknown (big cabinet)
OS: Windows 10 Home 64-bit
My computer is around 2-3 years old, but it has the same problems as the day i bought it, and it havent shown reduced performance since, neither better performance.
Thanks for your time!! I can provide furthermore information if needed.
Many regards, Chris.
Seeking help!
Ram: 8,00 GB
