FPS drops freezing lagging for no reason while playing games
Addie_72
59
Please help i have sudden fps drops lagging and freezing when i play games like fifa, cod ww2, re7 fallout 4, etc no matter the settings. Sometimes my whole pc freezes and the image changes into distorted colours.
I dont know whats causing it. Cpu and Gpu temps are fine and have also disabled Eist in the bios so that the cpu remains at its full clock speed. GPU temps are around 80c and CPU around 60c.
Gpu drivers are updated to the latest version and i have also tried uninstalling them completely and reinstalling them. There is also a sort of lagging sound coming from the pc cabinet like lagging power sounds when the drops happen.
specs:
gtx 760
i5 4570
msi b85m-g43(mobo)
single stick 8gb ram
corsair cx600 psu
seagate barracuda 1tb hDD
a sort of lagging sound coming from the pc cabinet like lagging power sounds when the drops happen. That can be caused by that HDD.
DirectX function "GetDeviceRemovedReason" failed with DXGI_ERROR_DEVICE_HUNG ("The application's device failed due to badly formed commands sent by the application. This is an design-time issue that should be investigated and fixed.")
Its application specific.
Some will run ok -particular ones not so much.
s master boot record menu in win 10 boot menu in should t appear unless there was an issue starting up last time.
Unfortunately prayers and chkdsk wont give you 60 fps stable. None of these games either very demanding anymore - games like dishonored, la noire, Tomb raider, skyrim. The 760 shouldn...
You install a fresh OS however you installed the OS on your old system. If you don't have an installation disk, flash drive, or the microsoft account the OS is tied to, you'll need to buy a new copy of windows.
I recommend disconnecting the old HDD when you're installing the OS.
All good now. Enjoy. Leave a accept as solution to your initial problem to also help other people experiencing similar problem so they can take it into consideration.
Have a nice day.
