FPS Drops in Several Games, Please Help!
ErieTheOwl
12
My Computer has lag spikes in different games, For Example Black ops 3 has around 80-100 fps low settings and it drops to 20 for like 20 seconds randomly, same for games like Far Cry 4 and CS:GO, I've tried alot to fix it, drivers are up to date, Cleaned my pc, scanned for virusses and malware. I think its maybe a overheating problem since yesterday my pc shut itself down without a warning my CPU and Motherboard are around 81 Degrees in Black ops 3
MY SPECS:
OS: Windows 7 Home Premium 64-bit SP1
CPU: AMD FX-6300
RAM: 8.00GB Dual-Channel DDR3 @534MHz
Motherboard: ASRock 960GC-GS FX
GPU: 2047MB NVIDIA GeForce GTX 960 (MSI)
Monitors: SyncMaster (1920x1080@60Hz) / V193WL (1440x900@60Hz)
Storage: 465GB Western Digital WDC WD50 00AAKS-65V0A0 SATA Disk Device (SATA) / 931GB Seagate ST1000DM 003-1ER162 SATA Disk Device (SATA)
Optical Drives: TSSTcorp CDDVDW SH-S223L SATA CdRom Device
Audio: Razer Kraken 7.1 Chroma
Well as for black ops 3 that dropping in framerate is normall,but not for so long... because it is a poorly ported pc game. Seems you are right that this is an overheating issue. 81 degress is to high for Just playing a game in my opinion
What shall I do to fix the Overheating problem, I already cleaned my pc from dust and thermal paste on the proccesor is like 3 months old, Any ''Cheap'' Tips?
So to get a stable good fps in most games your suggest that I get a new motherboard and maybe some more cooling?
Which motherboard should I get that is strong enough for my Processor? (As cheap as possible :) )
Sorry if I sound soo stupid, I've looked up those components and there indeed a cheap option, but you said something about overclocking, I now a little bit what it is in the way that you make your CPU go faster but how do I do it? does it overclock automaticly or do I need to turn it on etc.
My dad has a ASRock B85 Killer Motherboard is that one strong enough for my Processor?
That one is for Intel not AMD.
Give us link from where you buy your PC stuff and your budget so we will pick you something.
Doing mild overclock to lets say 4.3 Ghz on FX 6300 is rly easy.
Disable power saving options, set Multiplier to 21.5 for total 200(Bus Speed) x 21,5 Multiplier = 4300 Mhz and all you have to now is to bump CPU Voltage to get it stable.You can even leave it on auto for mobo to do it.You will have a bit higher temp just a bit and it will work without problems.
Good coolers for mild overclock are CM EVO 212 and CM TX3, Rajintek Aidos and Themis and CRYORIG H7.
Any of those will keep temps in check at safe level with much much less noise.
My dad has the Intelcore i5 4460 3,20GHz, if I use his motherboard and Processor should that be fine?
Do you really need to, since I dont like doing that and re-installing all my games etc. and win10 is a bit too expensive to buy.
I got a cracked win 7 cd-key ill use to re-install windows when I get the new motherboard
