fps drops with fx 8320 970 extreme 4
Simeon_1
Commendable
Jul 11, 2016
5
hello before i was playing all games okay for months with cpu OCED to 4.0 but the fps drops started from 100+ fps to 20-40 for some seconds and thn back up I searched for this problem and turned my cool n quet off
it did the job for some days and the problem came back please guys help
btw im using evo 212 and the fan of it is turned against my video cards back
http://imgur.com/nG9cNB5 this is a picture when i did a small ffts with prime 95
sorry for bad english
No, but it will limit the speed of the computer and shorten the life of your motherboard.
The ASRock 970 Extreme 4 motherboard has VRMs (power delivery system) which can overheat with a FX 6300. An overclocked FX 8320 is certain to result in thermal throttling of the motherboard, eventually. It seems that you have reached that point.
As a test, temporarily use zip ties to move a case fan to blow directly on the VRMs. (components between CPU socket and rear I/O panel)
well i dont have space for that 212 evo is too big
P.S. could this problem be the dust on the GPU and on the MOBO
gonna clean it in 1-3 days and i will see but im looking to solve it by bios options
if my vrms temp is the problem will it do something on the life of the CPU??
