FPS low
arjun14_u
9
hello guys
i use xfx nvidia gts 250 i get random fps drop in an interval of every 20 secs i get around 180 to 200 fps when normal and get fps drop of 10 to 15 for some 5 seconds den normal if checked my card in another pc it works fine but it happens in my pc any suggestion guys
MY SPECS
intel i7 920@2.6 ghz
8gb ddr3 memory
cooler master 600W smps
MSI x58 pro-e motherboard
xfx nvidia gts 250
hello guys
MY SPECS
8gb ddr3 memory
xfx nvidia gts 250
i installed windows 2 weeks back
my CPU runs in 85 C and my graphics card runs in 75 C
but my card runs fine in others pc but only in mine can u suggest some ideas to overcome that
Well 85 celsius is too high for a CPU period. Most likely your CPU is stepping down speeds to try and cool itself off. Take off the CPU cooler an dmake sure theres thermal grease, not too much, clean it very well before you reapply. All I can tell ya.
ok thx a lot ll try it out
CPU is throttling due to overheat... when temperature lowers, it goes back to normal speed, heats, bla bla...
heatsink not installed correctly is my guess... put your hand on it (be carefull), 85c should be very hot on the heatsink.. if its coolish, heatshink is incorrectly installed
i ve a coolermaster V10 cooler may i know where to touch and see????
BE CARFEULLLLL
Anywhere on the metal fins.... Heat is transfered from the pipes to fins... pipes should be very hot at 85c (100c is boiling water) fins should be at least warm..
