FPS lower than expected... [GTX 980 Ti]
Aug 17, 2018
7
I will try to keep this short;
My GPU: EVGA GTX 980 Ti FTW ACX 2.0+
My CPU: i7-6700K
RAM: 16GB
From about a few months ago, I have been noticing "not-as-good-as-it-should-be" performance.
Recently, I played DOOM 2016 and instantly realised that my FPS were about 35 FPS OFF! (at some parts, atleast), I was able to tell because I had made a video of me showcasing DOOM's arcade mode in which I was getting stable 130-150 FPS (in the first 2-3 minutes). Not only that, my FPS dropped to 50 at one point (it remained 50 there) when I was playing SkyrimSE. Same thing happened in FFXV. Needless to say, I was pissed.
I did Superposition Benchmarks and my score was 3862, which is pretty normal for my GPU, which leads me to my question. What in the world could be causing my FPS to drop so much? Please tell, I am very worried. Thank you!
Link to the video: https://www.youtube.com/watch?v=5GU74U2E9IU&t=119s
Replaced it recently and the temps are normal. From 35C to 45C
I meant that for the CPU as you mentioned the CPU throttling. Sorry for the confusion.
I did actually disassemble the GPU (*my cables are separate) but I think I know what could be causing the problem, for some reason, the GPU usage drops from about 100% to about 50% which causes the frames to drop, if you know how I can fix that, please tell.
