Question FPS spikes and random freezing ?
stillskill123
Commendable
Nov 8, 2022
15
Hi everyone , for the past couple of weeks I have been experiencing some spikes and freezes in pretty much all of my games . It started off with just a few unoptimised games like Squad and then I noticed it in all of the games I play including CS2 , Apex Legends and some other Esports titles. It happens when I walk around the maps/area or in some games when I scope into my weapon or even shoot.
System Specs
Mobo: Asus Rog Strix B650E-F Gaming WiFi
CPU: Ryzen 7 7800X3D
GPU: RTX 4080 SUPER 16G GAMING X TRIO
RAM: 32GB Corsair Vengence RGB 6400Mhz at cl32 or 30 (I can't remember exactly)
PSU: Corsair 1000w Platinum
CPU Cooler: Arctic 280mm AIO
Drives: WD_BLACK SN850X 1000GB and SAMSUNG MZVL21T0HCLR-00B00
I am gonna start with just saying that my temps are all normal, my GPU under 100% load doest`t go above 62-63 degrees celcius and the CPU I have never seen it above 72 degrees celcius.
Everything I have tried to fix the problem:
  • Default bios settings
  • New windows installed
  • Both SSD have been tested separately , their health is above 96/97 %, crystal disk has been used and cleardisk info
  • I used to have a rtx 3080 aourus which had been replaced with the new rtx 4080 (I know 5000 series is coming yes)
  • Before installing new drivers I always use DDU and NVcleaninstall
  • Bios updated and have tried a few versions and found the most stable one.
  • Chipset Drivers updated to the newest
  • Gpu drivers have been updated to the newest , tried a few revisions of the drivers all are the same pretty much .
  • MEMTEST , windows memory diag as well.
  • System tested with OCCT program , all passed even PSU .
  • Tried default Nvidia Control Panel .
  • I have Process Lasso Pro which is tuned for gaming (I can give further details if needed)
  • CPU cores have been unparked by CPU parking program.
  • CPU has been tuned in the bios , PBO is on with -16 in the optimizer , I have tested it without PBO or default PBO settings as well nothing had changed.
  • Tried disabling HAGS , small change there the spikes were less often but fps was also slighly lower in most games . But other times the spikes were the same without HAGS or with HAGS.
  • I have been running and custom power plan so far and until now I have had no issues with it .
  • I have game bar totally disabled using command prompt .
  • I have scanned my pc for malware using MalwareBytes.
  • SFC/scannow has been done , found 1 file corrupted but it didn`t fix my issue.
As you can see I have tried pretty much everything and all components pass all of the tests I have done , so in my head it has to be some setting or something that I am missing as these spikes aren`t due to overclock or anything like this I have ran the pc for a few days now with default bios and default nvidia setting and yet the issue persists . If you have any ideas whatever it is let me know .
Just to add , I have just tested my pc with Latency mon and dxgkrnl has been seen to cause some high spikes of latency as well as Wdf01000.sys and finally nvlddmkm.sys
What BIOS version are you on for your motherboard?
Got a link to the ram kit you're using?
I tend to use DDU to remove all driver(Intel, AMD and Nvidia) then manually install the latest sourced from Nvidia's support site in an elevated command, i.e, Right click installer>Run as Administrator.
This is a link for my exact RAM its cl32 :
https://www.amazon.co.uk/dp/B0BPL82...1EC76MNP52EN&starsLeft=1&skipTwisterOG=1&th=1
Bios version : 3024 , date i belive was 08/02/2024 , this is the most stable bios I have found for my system and I have been running it for over 3/4 months now.
These are my latencymon results I have 2:
CONCLUSION
_________________________________________________________________________________________________________
Your system seems to be having difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:07:53 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: STILIYAN
OS version: Windows 11, 10.0, version 2009, build: 26100 (x64)
Hardware: System Product Name, ASUS
BIOS: 3024
CPU: AuthenticAMD AMD Ryzen 7 7800X3D 8-Core Processor
Logical processors: 16
Processor groups: 1
Processor group size: 16
RAM: 32402 MB total
CPU SPEED
Reported CPU speed (WMI): 420 MHz
Reported CPU speed (registry): 420 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 193.30
Average measured interrupt to process latency (µs): 4.491676
Highest measured interrupt to DPC latency (µs): 192.0
Average measured interrupt to DPC latency (µs): 2.608844
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 54.380
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0.001508
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.001508
ISR count (execution time <250 µs): 219175
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 1852.470
Driver with highest DPC routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total DPC routine time (%): 0.055684
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0.116399
DPC count (execution time <250 µs): 2036203
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 0
DPC count (execution time 1000-2000 µs): 2
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: uagame.exe
Total number of hard pagefaults 29757
Hard pagefault count of hardest hit process: 18261
Number of processes hit: 53
PER CPU DATA
CPU 0 Interrupt cycle time (s): 25.44280
CPU 0 ISR highest execution time (µs): 12.850
CPU 0 ISR total execution time (s): 0.097696
CPU 0 ISR count: 177535
CPU 0 DPC highest execution time (µs): 1852.470
CPU 0 DPC total execution time (s): 8.489553
CPU 0 DPC count: 1725116
CPU 1 Interrupt cycle time (s): 0.964466
CPU 1 ISR highest execution time (µs): 3.710
CPU 1 ISR total execution time (s): 0.001017
CPU 1 ISR count: 926
CPU 1 DPC highest execution time (µs): 28.90
CPU 1 DPC total execution time (s): 0.007881
CPU 1 DPC count: 8711
CPU 2 Interrupt cycle time (s): 1.604708
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 31.440
CPU 2 DPC total execution time (s): 0.038572
CPU 2 DPC count: 58565
CPU 3 Interrupt cycle time (s): 1.198092
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 28.260
CPU 3 DPC total execution time (s): 0.008677
CPU 3 DPC count: 8455
CPU 4 Interrupt cycle time (s): 1.608638
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 32.190
CPU 4 DPC total execution time (s): 0.029955
CPU 4 DPC count: 31904
CPU 5 Interrupt cycle time (s): 1.056693
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 56.760
CPU 5 DPC total execution time (s): 0.011611
CPU 5 DPC count: 15366
CPU 6 Interrupt cycle time (s): 1.463541
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 30.110
CPU 6 DPC total execution time (s): 0.026457
CPU 6 DPC count: 28557
CPU 7 Interrupt cycle time (s): 1.170125
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 25.050
CPU 7 DPC total execution time (s): 0.005851
CPU 7 DPC count: 6834
CPU 8 Interrupt cycle time (s): 1.470797
CPU 8 ISR highest execution time (µs): 0.0
CPU 8 ISR total execution time (s): 0.0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 24.770
CPU 8 DPC total execution time (s): 0.021096
CPU 8 DPC count: 21128
CPU 9 Interrupt cycle time (s): 1.133065
CPU 9 ISR highest execution time (µs): 0.0
CPU 9 ISR total execution time (s): 0.0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 26.320
CPU 9 DPC total execution time (s): 0.027979
CPU 9 DPC count: 24184
CPU 10 Interrupt cycle time (s): 1.639406
CPU 10 ISR highest execution time (µs): 0.0
CPU 10 ISR total execution time (s): 0.0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 53.110
CPU 10 DPC total execution time (s): 0.023149
CPU 10 DPC count: 19921
CPU 11 Interrupt cycle time (s): 0.975132
CPU 11 ISR highest execution time (µs): 0.0
CPU 11 ISR total execution time (s): 0.0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 25.70
CPU 11 DPC total execution time (s): 0.014965
CPU 11 DPC count: 11145
CPU 12 Interrupt cycle time (s): 1.673498
CPU 12 ISR highest execution time (µs): 54.380
CPU 12 ISR total execution time (s): 0.004958
CPU 12 ISR count: 12841
CPU 12 DPC highest execution time (µs): 32.050
CPU 12 DPC total execution time (s): 0.035910
CPU 12 DPC count: 25170
CPU 13 Interrupt cycle time (s): 1.181786
CPU 13 ISR highest execution time (µs): 2.410
CPU 13 ISR total execution time (s): 0.003576
CPU 13 ISR count: 10224
CPU 13 DPC highest execution time (µs): 33.130
CPU 13 DPC total execution time (s): 0.012268
CPU 13 DPC count: 12336
CPU 14 Interrupt cycle time (s): 1.705148
CPU 14 ISR highest execution time (µs): 3.190
CPU 14 ISR total execution time (s): 0.004659
CPU 14 ISR count: 11367
CPU 14 DPC highest execution time (µs): 53.050
CPU 14 DPC total execution time (s): 0.046237
CPU 14 DPC count: 28993
CPU 15 Interrupt cycle time (s): 1.267251
CPU 15 ISR highest execution time (µs): 3.110
CPU 15 ISR total execution time (s): 0.002255
CPU 15 ISR count: 6282
CPU 15 DPC highest execution time (µs): 44.650
CPU 15 DPC total execution time (s): 0.013539
CPU 15 DPC count: 9820
AND THE SECOND ONE :
CONCLUSION
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 0:14:03 (h:mm:ss) on all processors.
SYSTEM INFORMATION
BIOS: 3024
Processor groups: 1
RAM: 32402 MB total
CPU SPEED
Highest measured interrupt to process latency (µs): 147.50
Average measured interrupt to process latency (µs): 5.743595
Highest measured interrupt to DPC latency (µs): 146.40
Average measured interrupt to DPC latency (µs): 3.156932
REPORTED ISRs
Highest ISR routine execution time (µs): 12.080
Highest reported total ISR routine time (%): 0.001990
Total time spent in ISRs (%) 0.001990
ISR count (execution time <250 µs): 457555
REPORTED DPCs
Highest DPC routine execution time (µs): 262.590
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 551.86 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.103498
Total time spent in DPCs (%) 0.188958
DPC count (execution time <250 µs): 4474328
DPC count (execution time 500-10000 µs): 2
DPC count (execution time 1000-2000 µs): 0
Process with highest pagefault count: msmpeng.exe
Total number of hard pagefaults 5891
Hard pagefault count of hardest hit process: 5666
Number of processes hit: 20
PER CPU DATA
CPU 0 Interrupt cycle time (s): 67.864050
CPU 0 ISR highest execution time (µs): 12.080
CPU 0 ISR total execution time (s): 0.211437
CPU 0 ISR count: 338112
CPU 0 DPC highest execution time (µs): 262.590
CPU 0 DPC total execution time (s): 25.032735
CPU 0 DPC count: 4032875
CPU 1 Interrupt cycle time (s): 2.192976
CPU 1 ISR highest execution time (µs): 3.470
CPU 1 ISR total execution time (s): 0.007575
CPU 1 ISR count: 6000
CPU 1 DPC highest execution time (µs): 26.070
CPU 1 DPC total execution time (s): 0.017809
CPU 1 DPC count: 12647
CPU 2 Interrupt cycle time (s): 3.036203
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 32.380
CPU 2 DPC total execution time (s): 0.050665
CPU 2 DPC count: 95887
CPU 3 Interrupt cycle time (s): 2.240120
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 24.210
CPU 3 DPC total execution time (s): 0.006480
CPU 3 DPC count: 5557
CPU 4 Interrupt cycle time (s): 2.822604
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 24.020
CPU 4 DPC total execution time (s): 0.025732
CPU 4 DPC count: 28436
CPU 5 Interrupt cycle time (s): 1.903985
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 18.20
CPU 5 DPC total execution time (s): 0.007084
CPU 5 DPC count: 8922
CPU 6 Interrupt cycle time (s): 2.741325
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 27.470
CPU 6 DPC total execution time (s): 0.022044
CPU 6 DPC count: 25944
CPU 7 Interrupt cycle time (s): 2.259832
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 23.20
CPU 7 DPC total execution time (s): 0.003817
CPU 7 DPC count: 3596
CPU 8 Interrupt cycle time (s): 2.871848
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 36.130
CPU 8 DPC total execution time (s): 0.027107
CPU 8 DPC count: 28589
CPU 9 Interrupt cycle time (s): 1.964041
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 22.220
CPU 9 DPC total execution time (s): 0.006904
CPU 9 DPC count: 6100
CPU 10 Interrupt cycle time (s): 3.612726
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 28.70
CPU 10 DPC total execution time (s): 0.024325
CPU 10 DPC count: 22933
CPU 11 Interrupt cycle time (s): 1.855336
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 27.210
CPU 11 DPC total execution time (s): 0.004442
CPU 11 DPC count: 4208
CPU 12 Interrupt cycle time (s): 2.999219
CPU 12 ISR highest execution time (µs): 3.510
CPU 12 ISR total execution time (s): 0.016652
CPU 12 ISR count: 37408
CPU 12 DPC highest execution time (µs): 32.650
CPU 12 DPC total execution time (s): 0.043336
CPU 12 DPC count: 33503
CPU 13 Interrupt cycle time (s): 2.477553
CPU 13 ISR highest execution time (µs): 2.360
CPU 13 ISR total execution time (s): 0.008521
CPU 13 ISR count: 20882
CPU 13 DPC highest execution time (µs): 28.460
CPU 13 DPC total execution time (s): 0.029623
CPU 13 DPC count: 15902
CPU 14 Interrupt cycle time (s): 3.772454
CPU 14 ISR highest execution time (µs): 3.60
CPU 14 ISR total execution time (s): 0.016437
CPU 14 ISR count: 36268
CPU 14 DPC highest execution time (µs): 51.910
CPU 14 DPC total execution time (s): 0.160476
CPU 14 DPC count: 134177
CPU 15 Interrupt cycle time (s): 2.468279
CPU 15 ISR highest execution time (µs): 2.810
CPU 15 ISR total execution time (s): 0.007907
CPU 15 ISR count: 18885
CPU 15 DPC highest execution time (µs): 76.360
CPU 15 DPC total execution time (s): 0.029301
CPU 15 DPC count: 15054
You have BIOS updates pending.
As for the ram kit, I'd have picked something up with AMD's E.X.P.O advertised on it. Sadly I can't tell much from that Amazon listing. Can you pass on the part number of the ram kit so I can narrow it down off of Corsair's site? I'm pretty sure it doesn't have an AMD E.X.P.O profile baked into it.
I have been using the pc as it is minus the gpu for over 5/6 months since building it and have had 0 issues until now . Here is the part number ‎CMH32GX5M2B6400C32.
The Ram was used in my old Intel 13th gen build but I have had no issues with it on both the intel and amd system.
Make sure to clear CMOS after each bios upgrade/rollback. This is important.
Ideally you need to update to the latest bios, clear CMOS, then run system at stock, no tuning other than expo - a baseline.
I get it that my bios is not the latest version but this has been stable ever since I have installed it back 3-4 months ago , I really haven`t changed anything on the pc other than the GPU and the GPU was changed after the issue occured.
Just an update :
-Bios has been updated to the latest with all chipset and all other mobo drivers (Lan Bluethooth , wifi etc).
-CMOS was also cleared
-Windows was updated as well
- I ran the system bone stock even without Ram expo/xmp
Conclusion , I am still experiencing those spikes , I was adviced that it could be DX12 in those games that I play that cause this , like initial render of maps etc.
