First_timez_pc_builder :
106Nilsson :
Hi! I learnt a lot from this thread! +1!
I am on my way buying a Fractal Design Define R5 case, and was thinking of adding one additional FD Dynamic GP-14 fan at the front (same as the two included, you can buy them now) and using a Noctua NH-D15 CPU cooler. Should be sufficient airflow from that. Planning on a Gigabyte GTX 980ti GPU (with fans that stops at low temps) as well as a EVGA SuperNOVA 750W PSU with eco mode that stops fans at low loads.
Since silent gaming is my goal, this should be fairly good? Will be first PC build ever, and so far I've spent days reading up on everything! Haha.
Aiming for 3440 by 1440p gaming with G-Sync.
Great community!
Hey, I am building almost the exact same setup, with NH-D15 cooler.
How did you orient the cpu cooler?
Are you happy with the overall setup?
Hi!
I am afraid that I've not yet purchased the new build
😛 Decided to wait for the Nvidia GTX 1080 GPU, which has yet to arrive in stock at the stores I have access to here in Sweden. Should be within a couple of weeks now. However, since I am going away for most of the summer for vacation, the PC will be bought in late august/early september. So I can't say from personal experience how it will perform
The plus side is that I've had a lot of time to finalize the PC parts list and I am very confident of the system I've got planned
About the NH-D15 Cooler, I would/will orient it so that the two fans exhaust to the back exhaust fan (basically turning the D15 into a push/pull/pull with the exhaust fan) I will not remove the Moduvents since silent operation is a main concern.
Hope it helps! Good luck with your build! When you finish it, I would be happy if you would share any experiences with the build here! Cheers!
My parts list (quite finalized)
http://pcpartpicker.com/list/Mj4vKZ
