Fractal Design Edison M Series 750W Power Supply Review
there are several issues with there testing. first power good signal is not a good base for testing as its simple to "Cheat" the 16ms hold up.how about actually watching power good vs output voltages also. also the thermal camera scall changes every time how about using a fix scale as modifying scales leads to making things show hot that are not really that hot.
Aris_Mp
Contributing Editor
Editor
Feb 5, 2015
297
9
10,785
First of all I measure AC loss to PWR_OK hold-up time since it is much easier to show it in my graphs and explain it. For me it is as easy to measure "AC loss to PWR_OK hold-up time" plus "PWR_OK inactive to DC loss delay" but I prefer it the way I do it.
Also where do you base this? That the PG signal is simple to cheat and the manufacturers actually do this? From the moment the mainboards take seriously into account PG if this was the case then most likely there would be huge problems with lots of them. According to the ATX spec PG is de-asserted to a low state when any of the main rails falls out of 5% v. reg. Simply as that.
It just gives room for 1 ms till the PG signal sees the change at least in the ATX spec.
As for the thermal camera how it can show things hotter than it is? The scale is for this reason and from the moment the camera sees something from a different angle and a different region the scale is changing automatically. Nothing I can do about it. This is why I provide also actual temperature readings on all IR images.
PaulBags
199
A quick opinion on the edison vs similar range seasonic own brand would be nice. Is it a new design, or an exact rebrand of a seasonic design? Quality of components vs?
Aris_Mp
Contributing Editor
Editor
Feb 5, 2015
297
9
10,785
This is based on the same platform with the Seasonic G series and I state this in the "look inside" page. I haven't tested the G750 so far but I believe that since they are based on the same platform performance will be similar. Seasonic might used Enesol polymer caps (something that they usually do in their G units) instead of Chemi-Cons that Fractal chose, but both cap brands are very good so don't expect to see any real performance difference on them (although I prefer Chemi-Cons).
So the design is nothing new and this is a Seasonic rebrand with minor differences at the internals (most likely the caps selection as I stated above).
Aris_Mp
Contributing Editor
Editor
Feb 5, 2015
297
9
10,785
Forgot to mention that besides caps the cooling fan is also different since on all Seasonic G units that I have tested so far have an ADDA double-ball bearing fan while the Edison PSU uses an FDB fan. However lately I noticed that many Seasonic units use Hong Hua FDB fans instead of ADDA double-ball bearing ones, so it is possible that this change might have affected the new bunches of G units.
You say that you'd prefer if the unit was fully modular, but I don't really see the point.
The fixed cables are the ones that will always be in use for any system using a 750W power supply, so the ability to disconnect those cables would not be beneficial. In fact it would lead to higher cost and also an extra point of failure and a slight loss of efficiency since a connector can never quite match an uninterrupted cable.
Aris_Mp
Contributing Editor
Editor
Feb 5, 2015
297
9
10,785
fully modular cables provide easier installation and cable management. Also you can easily change them with longer/shorter ones if you like or replace them in case there is a problem with them or simply you want something fancier.
Loss of efficiency isn't a reason any more, on the contrary with bus bars or thick cables transferring power to the modular PCB energy losses can be minimized. In addition no cables block the secondary side caps, something that besides increasing their lifetime also allows for more relaxed fan profiles and better airflow inside the chassis.
Also the cost of a semi-modular to fully modular isn't high and in a 750 W PSU that costs 140 bucks already the cost reason doesn't stand (for fully modular design).
No they don't. The connector on the power supply end adds complexity and reduces cable flexibility.
You cannot easily change them because other cables are often incompatible - there is no common standard for modular PSU cables. Using incompatible cables can be downright dangerous. Here is a cautionary tale.
Aris_Mp
Contributing Editor
Editor
Feb 5, 2015
297
9
10,785
I didn't say that you can change them with anything, did I? Also it is common sense that every manufacturer uses their one design on modular cables. Thing is that with modular PSUs you can get an extra cable kit since most manufacturers sell one for their PSUs (e.g. Corsair, EVGA).
Also I still cannot understand how the connector on the PSU end adds complexity and reduces cable flexibility! Cable flexibility depends on the gauges' thickness and not on the cables modularity design (or not).
Anyway I believe I made my opinion clear on why I prefer fully-modular PSUs.
Complexity because you need to plug it in two places, and of course it adds internal complexity in the PSU design as well.
Less flexibility because the first centimeter or two from the power supply will be a hard plastic connector instead of wires that can bend. One more thing to account for in a small form factor case.
Aris_Mp
Contributing Editor
Editor
Feb 5, 2015
297
9
10,785
You can simply connect it before hand if you think that this makes things complex (at least you have this option in a fully modular but you don't have the option to remove a native cable if this would make the PSU's instalallation easier). Also as I stated above from the moment a PSU has already some modular sockets it is easier and preferable to make it fully modular since this way you can avoid the cables that leave from the mainboard and end to the main ATX or EPS/PCIe connectors. This allows also for better cooling of the secondary side caps, something that leads a longer lifetime for them AND a lower overall noise output since you don't have to use a high RPM fan to effectively cool them.
As for the less flexibility for the first centimeter, if you PSU will be such a tight fit for your case then you should consider buying a smaller one (or a larger chassis) and not a semi-modular PSU over a fully-modular one.
