Hi, I'm picking parts for a build for a friend and so far the only good affordable case for which I didn't get a "that's ugly" comment is this one
Fractal Design Focus G Black ATX Mid Tower Computer Case
But I do have a few small things I'm wondering about
First, I intend to use two mechanical hard drives and one SSD, from what I'm seing the SSD drive mount is placed behind the PSU, would having no ventilation at all in what looks like a very small enclosed space be an issue?
Second, how loud are the included fans?
The only info I found is 24.8 dBA. I assume that's only if the fan is going at full speed but still I'm wondering what it might sound like. I'd like to keep the build as quiet as possible.
Otherwise I'm also open to other case suggestions, so far the ones that got denied are
Corsair - 200R ATX Mid Tower Case
Corsair - SPEC-02 ATX Mid Tower Case
Requirements are
- Under 100 $ CAD (approx. 60-70 US)
- at least 1 external 5.25 drive bay
- Room for 2 mechanical HD and 1 SSD
- Dust filters (2 cats in the house)
- At least 2 front usb 3 ports, I also looked for cases with usb Type C (future proofing) but so far haven't found anything in my price range, and I'm assuming the motherboard would require a specific USB header for it.
- Fans with LEDs (if it weren't for that I'd go for Noctua fans)
- ATX Mid-tower or smaller
If it makes a difference this is the build I came up with so far (still haven't nailed down the motherboard and video card brands but it's a good start.
CPU: AMD - Ryzen 5 2600X 3.6GHz 6-Core Processor ($274.99 @ Amazon Canada)
Motherboard: ASRock - B450M-HDV Micro ATX AM4 Motherboard ($96.99 @ Newegg Canada)
Memory: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3200 Memory ($182.99 @ Newegg Canada)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive ($98.99 @ Amazon Canada)
Storage: Seagate - Barracuda 1.5TB 3.5" 7200RPM Internal Hard Drive (Purchased For $0.00)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($74.99 @ Amazon Canada)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SSC GAMING Video Card ($364.99 @ Newegg Canada)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case ($74.99 @ Newegg Canada)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.99 @ Amazon Canada)
Optical Drive: Asus - DRW-24B1ST/BLK/B/AS DVD/CD Writer ($29.99 @ Newegg Canada)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($119.99 @ Newegg Canada)
Case Fan: Fractal Design - FD-FAN-SSLL-120-WT 41.8 CFM 120mm Fan ($12.99 @ Newegg Canada)
Total: $1431.89
Generated by PCPartPicker 2018-10-24 23:34 EDT-0400
Thank you very much
Requirements are
Total: $1431.89
Thank you very much
