Hello,
I am trying to increase clarity of my microphone by removing unnecesarry/potential background noise makers.
I've read unpluging the front panel audio jacks helps. As they are usually crappy.
HOW DO I ACCESS THE PLUGS of Fractal Design Define Nano S, MicroITX case?
I've opened the case but wires to the front panel are unnacesable like that, unless i'd start puling out them with some pliers. Fingers don't fit there.
I've also opened the case's front panel, removed the filter. But all the wires are encased in a plastic case, this way they are totally unacessable.
How did my computer engineer plug motherboard wires into the front panel? Any trick? I really need to pull it out, i know my on-board amplifier picks up lots of noise from it.
EDIT: Ok i think those wires are actually hardwired to the case? Is that the case? In that case - i only need to find the AUDIO plug going to mother board and unplug it. Would be nice if i could also pul it out of the front panel as it's extra wire/antenna. Can someone tell me if they are hardwired or removable from front panel.
