[SOLVED] Frame-drops and random stuttering/repeat frames ?
candlelarbra5212
119
Hello, I have an issue wher my PC will freeze and drop frames when gaming/in general use. The FPS count doesn't dip but it looks like it's dropping frames. Sometimes it will repeat a frame. For example when when shooting in Overwatch if I have fired a shot it will animate the shooting twice and the character will skip instead of walking smoothly. I have run Restoro and couldn't see any issues, done DDU and a clean install of drivers. Temps all look good, below 60c max load. There is another issue where my keyboard will give conflicting info so if I press W when walking in game it will move my character backwards, I have been unable to recreate this issue when typing. Does anyone have any ideas, my sytem is:
ASUS ROG B350i Strix Mobo
Ryzen 5 3600 @stock speeds
Galax RTX 2070 Super (1-Click OC)
16GB GSkill Trident Z RGB Ram
Corsair 650W PSU
Corsair 650W PSU
Tried to use 1 PCIe/GPU Cabel per power slot on the gpu yet? So 2 separate power cable for 2 slots, sometime it fixes the problem.
Are you sure you aren't just dealing with lag issues? Online multi player games will do that when resynching. Is the issue showing up when playing single player offline games? I have been seeing a few individuals who are buying hot GPUs thinking their cards are messed up when it is just the internet.
