Review Framework Laptop (12th Gen, 2022) Review: Right (Way) to Repair
To me, the most important thing about this idea is that you don't need to scrap the entire laptop just to upgrade the CPU. My very old MacBook Pro from 2010 has a perfect screen, keyboard, etc., needing only a new trackpad to be in great working condition, but it just got completely obsolete because of the first-gen Core i7. If it were a Framework laptop, I'd replace the motherboard and keep using it until today.
I really hope they keep going and succeed, we need more like this.
I was going to order the Framework laptop but because of the long waiting period I decided to go with Lenovo Thinkpad E15 Gen4 with i5-1235U which works great for my needs. Everything about it is perfect except for the 2x 2248 m.2 slots instead of the usual 2280, but I ordered some adapters to fix that. I may come back to Framework for my next upgrade.
I own a Framework laptop, and the review gets MOST technical details correct. What's incorrect? The price!
Here's the actual cost of buying a top-end Framework:
Framework DIY edition with i7 1280P = $1530
WD Black SN850 2 TB = $240 from Amazon
G.Skill Ripjaws 32 GB (2 x 16GB) 3200C18D-32GRS from Newegg = $160
Windows 11 from an internet reseller = $40
Total = $1970
That is an incredible price. If you can a similarly equipped laptop from any other vendor, it'll run you about $2800!
When you combine the lower price with the substantially higher performance (10-30% according to the charts above), you can see that the Framework laptop is a massively better value than anything else around.
Oh, and when you break it, you can actually fix it. That'll save you another $2,000.
My ranking: 5 stars.
Total = $1970
How much does it weigh?
